05-07 dash bezel on 99-04? Will it work? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-13-2008, 03:00 AM
Monsta's Avatar
Monsta
Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Does anyone know definitively if the 05-07 dash will fit/work on a pre-05 truck?
Old 05-13-2008, 01:20 PM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
I'm 99% sure it will not work. What are you trying to do?
Old 05-13-2008, 01:29 PM
Overkill's Avatar
Overkill
Overkill is offline
FTE *******
Overkill is gaining momentum as a positive member of FTE.
The radio surround (in the actual dash) is different as well as the A/C ducts. It is not impossible but it won't be an easy swap.
Old 05-13-2008, 02:40 PM
Monsta's Avatar
Monsta
Monsta is offline
What I'm tryin' to do is use an 06 dash bezel (surround) in place of my 04 style. Just a thought.
If things don't line up well then ta heck with it. Plus I like things easy.
Old 05-13-2008, 03:27 PM
Beerstalker
I understand that, but why? Are you trying to install a double din stereo or something? If so you can fit one in your truck with just some minor trimming that won't even be able to be seen if you ever put the stock radio back in. I can give you more instructions on that if it is what you are trying to do.
Old 05-13-2008, 03:54 PM
Overkill's Avatar
Overkill
Overkill is offline
FTE *******
Ken,
Once you remove the bezel you will see that the actual dash is different. The opening for the radio is quite a bit larger on the '05+. Also the A/C ducts on the 99-04 are horizontal and vertical on the 05+, so they will not line up.
Old 05-14-2008, 04:17 AM
Monsta's Avatar
Monsta
Monsta is offline
I like the look of the updated dash. I have this "need" to make my Excursion into the Excursion Ford would still be making had they not killed it.
Looked like both vent designs were horizontal. I can always get a new radio. So it's settled? The clips will NOT line up?
Old 05-14-2008, 09:40 AM
Overkill's Avatar
Overkill
Overkill is offline
FTE *******
Not the vents, it is the actual ducts (behind the bezel) which are different. I actually removed the dash bezel off of my '05 SD and test fit it on my '05 Excursion and it would not fit without considerable modification.
Old 05-14-2008, 12:55 PM
Monsta's Avatar
Monsta
Monsta is offline
Damn...so it IS settled.
Thanks Overkill!!
Old 05-14-2008, 04:25 PM
Beerstalker
Yeah the entire structure behind the dash is different on the 05 up trucks (at least the top portion, the lower portion is the same). You would pretty much have to pull the entire dash out and swap in the new one.
Old 05-14-2008, 08:59 PM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
i tried the same thing. i have this one for sale..... SUPER CHEAP TOO>>>>>>>>
Old 05-14-2008, 11:42 PM
aortizexcursion's Avatar
aortizexcursion
aortizexcursion is offline
aortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputation
What if one was to buy the entire dashbord and all the hardware from the 05-07s from a junkyard truck, would it work then?
Old 05-15-2008, 09:08 AM
RACERX7775's Avatar
RACERX7775
sure it would work. but i wouldn't want to lay out that much for just a simple swap.
Old 08-29-2017, 01:47 AM
Stephendollarhide
Stephendollarhide is offline
Stephendollarhide is starting off with a positive reputation.
Dash bezel
do you still have this for sale I know it's a pretty old post
Old 08-30-2017, 02:16 PM
BioBurner's Avatar
BioBurner
BioBurner is offline
BioBurner is gaining momentum as a positive member of FTE.
Also: yes the clips line right up. No the vents don't line right up. I did this conversion on my old 02 a week before a drunk driver murdered it.
mrwrench
01-16-2018 08:40 PM
bdavis1369
WTB - Parts & other
10-27-2017 07:35 PM
kengarchow
10-04-2017 02:29 PM
Dstosh
WTB - Parts & other
08-06-2016 09:16 PM
HKusp
35
06-02-2016 10:51 PM
Quick Reply: 05-07 dash bezel on 99-04? Will it work?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
