Pyrometer reading low
To answer your question, it looks like you can get just the sending unit, but you'll have to check with your specific model. I just googled autometer pyrometer sending unit and the first few links had just the sender. They looked pretty steep, so it may help just to get the kit and replace it all. As far as which is bad, I'm sure you could find a way to check with an ohm meter to see if the resistance is right. It just depends on which model.
But like it was stated above, the DP isn't the best location, so if you have to order a new one, I'd leave the old probe where it is and drill tap the new in the manifold.
Oofda... bare minimum on the level at 65 MPH (empty) with the sensor in the exhaust manifold is 525 degrees. Jumake-a-me nervous with that 800/900 degree reading after the turbo. Ever felt an air compressor tank when running? Warm. Ever touch the open air nozzle? Cold. The pressure drop always cools things down pretty dramatically.
A bad sensor could read low temp, but I wonder about winter with all that cooling down. I notice my EGTs are running a little cooler straight off the engine (with the heavy-huffing 38R) and I imagine a cold blast on the downpipe would cool your breath.
The location of sensor has nothing to do with what the gauge was reading and to what the gauge is reading now. Same location both times, just was not reading up to par!
Gave a shout out to Cory at Autometer, and he replied with suggestions. My problem ended up being my ground wire(at the firewall) not making good contact. Cleaned and reconnected, and we are good to go again.
Twin Tritons
04-18-2004 10:22 PM
