converting to serpentine belt
I M TRYING TO CONVERT MY '85 351 TO SERPENTINE BELT DRIVE (also installing. radiator fan} DID A LITTLE LOOKING AT A JUNK YARD LAST FRIDAY ,BUT WAS NOT SURE WHAT I NEEDED.
LAST WEEK I POSTED A REQUEST FOR PHOTOS ON THE "ENGINE FORUM" --NO RSPONSE.
DOES ANYONE HERE HAVE CLOSE UP PICTURES OF THE BELT DRIVEN COMPONENTS AND BRACKETS OF A 351 OR 302 (v BELT OR SERPENTINE)?
I have 3 alternators ,no a/c compressor yet, several serpentine pulleys with a cameo front clip and GM steering column(need GM power steering pump) on my 48 f1. The guy at the junk yard was totally confused and no help. that is why I need all the pictures I can find. Help I'm confused.
Yes the water pump needs to be changed because it turns the oposite way of a V belt. This also meens the rad inlet and out let will be off. You can have a rad made or run the hoses up down and around to work if you have the room. The 302 parts will work but if I remember right the a/c bracket needs to be cut and extended because the 351 is wider then the 302. The balancer does need to be changed becuase the v belt is a 3 bolt and the serp is a 4 bolt if I remember right. Make sure the balancer comes off a motor with the same imbalance as yours or it will vibrate alot! The timming chain cover I think has mounting flanges and stand offs for the serp set up that you wil need. You best bet is go to a pick-n-pull and strip off the front of a 5.0 musatang and take every part and bolt. I think the 5.0 has the same imbalance as the 351's but double check first.
I have done several conversions and it is not that much work and well worth it.
Kevin
LFD inc.
Kevin
LFD inc.
I put a serpentine system on my 289, It came off a 87 302.
I used the timing cover, waterpump, and the alt off of the 302, also got a balancer for the 302 for the correct distance. Yes the water pump is a reverse rotation.
Here a Pic
https://www.ford-trucks.com/user_gal...185041&width=2
i also used all the cast Alum mounting brackets.
If you need I can get you beter pics.
Here a Pic
Here a Pic
Here a Pic
Kevin
LFD Inc.
Aaron-71
16
10-17-2014 05:23 PM
jack odom
10-18-2013 10:52 AM
ozblitz
18
05-13-2010 08:46 PM
W Thomas
03-04-2005 05:50 AM
