Spark plug disaster!!!
Old 05-10-2008, 04:53 PM
mrdemoss's Avatar
mrdemoss
mrdemoss is offline
Prt of reamost sparkplug broke offin cylinder on passenger side; got seven of eight in successfully. Need instructions on taking right cy head off; local dealer has bad rep on repairs, and i'm fairly handy with tools. Any help, aweb site, manual I could buy. THANKS
Old 05-10-2008, 05:37 PM
BIGGDAWG900's Avatar
BIGGDAWG900
BIGGDAWG900 is offline
If i am not mistaken you have to lift the body off of the frame or pull the motor to get the head off. I will check the manual to be sure.
Old 05-10-2008, 05:47 PM
FatalErrorz's Avatar
FatalErrorz
FatalErrorz is offline
Holy Bat****, are you frickin' SERIOUS?!? While I'm glad I have the redesigned heads and 1-piece plugs, I can't believe that!
Old 05-10-2008, 08:13 PM
slc10844's Avatar
slc10844
slc10844 is offline
There is a tool that is designed to remove broken spark plugs on the 3V 5.4. without removing the cylinder head. Buying the tool might be cheaper and faster than the cost of removing the head.
Old 05-10-2008, 08:29 PM
edf's Avatar
edf
edf is offline
The tool is a “Rotunda 303-1203 Broken Separated Spark Plug Removal Tool” it can be found on ebay or at http://www.denlorstools.com/home/dt1/page_13119_520/rotunda_303_1203_broken_separated_spark_plug_remov .html
good luck!<O</O
russellkr
11-02-2002 11:18 AM
beartracks
10-18-2002 02:20 PM
dale i
09-22-2002 09:37 AM
rogwelch
02-12-2000 11:29 PM
01-28-2000 06:08 PM
Quick Reply: Spark plug disaster!!!
