Oil filter leaks
Oil filter leaks
When I first got my truck it leaked a little around the oil filter and since then I have changed the oil and filter and it still leaks a little around where the filter is. I have cleaned really well and made sure the gasket was removed from the base before I put on the new filter...Any Ideas on how to fix it?
VOM FSeries/Econoline Owners guide 7.3 Liter Diesel
Clean the filter mounting area of the oil cooler, lightly coat the gasket surface with clean engine oil and hand tighten until gasket contacts the base. THEN TIGHTEN ANOTHER....... 1 1/4 to 2 TURNS. Fill the crankcase and check for leaks.
00 Nav
1997-2006 Expedition & Navigator
02-08-2009 01:06 PM
