Will an engine swap kill the value?
Due to the fence Americans are bent over I am considering what would be considered blasphemy in the FE forum. I currently have a '65 short wide F100 with the stock 352 in it. It runs good and was rebuilt by the PO a few thousand before I bought it. It has the usual bolt-ons but is stock internally as far as I know. I have a freshly rebuilt 302 on my engine stand with 0 miles. It is built mildly inside and out. How bad would I kill the value of my truck by swapping the two out? I would probably keep the 352 and just store it. This swap would also bring in the ability to run an overdrive tranny. I could also get a junk yard fuel injection to put on the 302 instead of the carb setup I have. Help me. I am lost and slowly going broke at the pumps.
Will the engine swap lower the value of your truck, is there something rare about your 65 verses the 65 I own or the 65 that any of the other members own on the FTE forum? I highly doubt there is anything extra special, as Ford cranked out thousands of these trucks. I don't have any number's but it has to be well over 100,000 and I am sure other members can tell exactly how many were made. Is your truck restored to the factory condition, or has it had a bunch of MOD's done, power steering, disk brakes, and so on? Are you trying to restore your truck to like new factory assembly line condition?
Really value is a relative term, what something is worth in your area will be different than in mine, and your truck and mine and everyone's is worth what ever a buyer is willing to pay. To me mine has high value as my grandpa bought it brand new and gave it to me when I turned 15. I can never part with it as the sentimental value is too high, is the truck really worth anything, not really.
I would say as long as you don't hack anything up to complete the swap the value should not change, since you can always put it back to stock. At least you are not transplanting a Chebby engine in.
I am currently transplanting a 4.6L MOD motor for improved driveability in my 65. I am sure it is not all FTE members taste to do that but it is my truck and that is the direction I want to go. I say if you want a 302 put it in.
Once again, just my two cents.
Jeff
I assume you are trying to improve the mileage of the truck. My thoughts are that the longer stroke 352 might get better mileage than a 302, you will have a heavy truck with lots of frontal area with either engine. I know you have a fresh 302, but I think a 300 inline 6 engine would be a better swap if you want economy.
What trans, rear axle ratio, and what size tire do you have on the truck now?
(tire size and/or diameter)
"mildly built"....what compression ratio does the 302 have? What trans do you have in mind for your swap? Do you have the trans yet?
My 352 with 3 speed gets 13-15 mpg if driven like an adult.
To move big chunks of weight such as these, you need torque, not HP. The 302 is not going to be any better in the fuel mileage dept, IMO. It's power band is much different, and is some ways may have to work harder than the big old FE.
There is a limit to what you can get with mileage on these. I would look seriously at your axle ratio, tire size and transmission. If it's an automatic, there's not going to be much you can do without changing the whole truck. Mid teens is all you should really expect. Aerodynamics and mass are working against you.
That said, we do have a club member with a six in his truck that has seen 22-24 mpg on trips.
Do what YOU want with YOUR truck. I plan on modifying mine and when I do resale value won't be a factor. It's kinda like a Harley. You can spend the time and money putting ALL that chrome on it but if you were to sell it you have to find the right buyer that likes all that chrome, too. Build it / drive it / modify it for you. These trucks don't have a huge resale anyway. Mine was 85% restored to original when I bought it and I got it for $3,500. Most I can expect to make on it if it were 100% restored would be $10k or $12k. The highly modified trucks sell for more than that.
SO - I suppose it's all in WHAT and HOW you do it.
ROb
Thanks for your opinions.
Stay with the 352, add dual exhaust if you don't have it. Consider headers- I put headers and 2 1/2" exhausts on mine and it really helped. I also run a performer 390 intake and an edelbrock carb. I live at 6200 feet so the edelbrock carb is easier to retune. I've talked to some people in Albuquerque (4000 feet) and a couple of them have run the holley 390cfm 4 barrel with good luck. I don't recommend the 302- I tried it years ago in a 75 f-150 and it got horrible mileage. I have a HUGE problem with the "drive like an adult" thing - I like to "buzz" rice rockets
I like the ( 351w ) I think they get better milage and will out power, and out
last all the motors listed above, just my 2 cents, i have drove all that is listed
above, and LOTs of ( 351w ) sure like the power they have!
P.S. BUT you sure could buy a lot of gas for what it would cost to change
your combo!
Wally Womack
