Speaker access
Old May 4, 2008 | 03:03 PM
Shovelhead 93's Avatar
Shovelhead 93
Speaker access
How do I get access to the speakers on my scab,front and back,I dont want to break anything and I cant seem to figure it out.
Old May 4, 2008 | 03:49 PM
soxfan81's Avatar
soxfan81
the fronts you just need a screwdriver and pry the grille off, the backs I think you need to remove the door panel. That is how it was on my screw.
Old May 4, 2008 | 05:21 PM
XolieX's Avatar
XolieX
you can buy a instruction manual from crutchfield and it shows you step by step how to take out the back speakers! if i can find the papers, maybe i can fax you over the instructions!
Old May 4, 2008 | 05:27 PM
black04lariat's Avatar
black04lariat
The rears: Pop off the panel on the side of the window and remove screw from behind it. There are 2 screws at the bottom if I recall correctly. Pop the panel in the door handle out and ther are 2 screws behind it. Pry off the window switch and there is one behind there. Then the panel should lift off.
I think thats all the steps...my memory could be off by a screw or so.
jeremiah77
Feb 7, 2015 09:36 PM
50man
Jul 25, 2013 05:10 PM
Bookman
May 2, 2011 09:27 PM
toa5150medic
Aug 4, 2010 02:09 PM
psd167
Mar 28, 2005 09:48 AM
