The best chassis Ford,Dodge or Chevy? - Page 7 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Reload this Page >
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #91
Old 06-01-2017, 05:45 PM
FordF350Superduty's Avatar
FordF350Superduty
FordF350Superduty is offline
FordF350Superduty is starting off with a positive reputation.
Originally Posted by Pkupman82 View Post
For those of you who live in the snow belt, have you even seen what happens to a GM frame when you put a big V-plow on it? Those stiff boxed frames crack pretty easily.
John
So WHY! Ford use boxed frame now ? -http://www.trucktrend.com/news/1509-five-hard-working-features-of-the-2017-ford-f-series-super-duty/
  #92
Old 06-02-2017, 05:54 PM
Louisville Joe
Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
I strongly suspect the 2017 Super Duty will compare much more favorably now:
  #93
Old 08-28-2017, 07:03 PM
mhatlen's Avatar
mhatlen
mhatlen is offline
2006 Bullet-Riddled 6.0
mhatlen is gaining momentum as a positive member of FTE.mhatlen is gaining momentum as a positive member of FTE.
Oh yea no doubt there, 23 times stronger says a lot. The frame in these F250's are pretty flimsy really. There are so many long bed trucks that have that resonance at 42mph and get that bounce. My old SCLB had it and it took some work in frame stiffening to get it to stop.
Once these trucks passed 7,000 lbs they should have upgraded the frame. Neighbor has a 2017 and it feels like it's on rails, these new frames are a game changer.
  #94
Old 08-28-2017, 09:52 PM
Louisville Joe
Wait a minute. So the 2017 Super Duty frame is 23X stiffer than the previous generation Super Duty, and the Chevy HD frame is 30X stiffer than the previous generation Super Duty? Did I read that right?
What PSI steel does Ford use in the Super Duty frame now? I know the Chevy HD uses 60k and the Ram uses 50k, can't find out what the Ford uses.
  #95
Old 08-29-2017, 04:59 AM
Fullsized-Fan
Fullsized-Fan is offline
Fullsized-Fan is starting off with a positive reputation.
Not sure but i recall it to be 50.000. Anyways the Ford frame ist bigger general dimensions of the rails:
Cheyv 215x88x4.5mm
Ford 240x89x4.7mm
Since the height of the frame is the most important part, i guess the Ford frame is quite a bit stronger now.
But i wonder when Dodge will follow this? 2018?
  #96
Old 11-15-2017, 11:56 AM
RXT
RXT is offline
RXT is starting off with a positive reputation.
Back in 2014, Here ya go;
Ed
  #97
Old 10-21-2018, 08:05 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.ATC Crazy has a great reputation on FTE.
I really don't like this "frame war" that manufacturers are in. I believe these ultra stiff frames are the cause of highway shake/vibrations you hear about on forums (Ram especially)
C-channels also don't hold water, dirt, and mud inside to rust out, and C-channels give us DIY mechanics access to, and a place to run new lines, etc... And yes, frame flex is a good thing.
Ford_Six
01-21-2017 01:34 PM
AlaskanEx
2017+ Super Duty
18
01-10-2017 08:38 PM
Richard O.
11-12-2016 08:48 AM
1x1_Speed_Craig
New Member Introductions
08-08-2016 11:50 PM
Jim Egan
06-19-2016 02:26 AM
Quick Reply: The best chassis Ford,Dodge or Chevy?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
