Pictures of the "MYSTERY PART" HELP!!
<HR style="COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>Sorry for starting yer another thread. Here are a couple of pictures of my mystery part.I have another thread going about an oil leak from the hpop. Well. I pulled the pump to fix the leak, and when I went to reinstall the pump, I found the mystery part. It's about an 3/4" long spring with a piece of metal capping it at one end. The cab has a small hole (.010) maybe, in the center it looks like the inside of a fuse holder. I finally said screw it and put it all back together without it and now it won't start. and yes, I did fill the hpop resevoir. And as of this morning, the resevior is still full so I don't thing it's part of the anti drainback valve, but hey, I've been wrong before.Anybody that hasn't read the other thread have a clue??
</TD></TR></TBODY></TABLE>
Attachment 9604
Attachment 9605
Attachment 9604
Attachment 9605
If you have a digital camera, please take new pictures. Turn off the digital zoom, and set it to it's maximum resolution first. Get your pictures, then before you upload them, crop it so only the part shows. This will help reduce the file size, so it will load faster. No offense but looking at those pictures is hurting my eyes. Thanks!!
on
Hard to tell from the fuzzy pictures.
Does it look like this?
plunger pictures from trucks photos on webshots
damn springs! How many times have you guys taken something apart, or were putting it back together, only to have a spring go flying off across the garage, sometimes never to be seen again. I think I spend more time looking for parts than I actually do fixing (or trying to fix) stuff.
on
Nice one Roland!
ok guys, I found the other one, and installed them in the fittings. Yes, I didn't have the tool to remove the lines from the fittings, so I just unscrewed the fittings from the pump. I still have no start. The resevoir is full. It was full of new oil, but now when I check it, black oil comes out, so I'm assuming that it's pumping, Any new ideas?
