Will taller tires help highway fuel mileage?
It has been my exerience that highway mileage is a function of air resistance (aka parasitic drag), which squares as the speed increases. the taller tires will tend to act as an overdrive, BUT will also raise the height of the vehicle which is generally 10% LESS mileage per inch raised.
The specific better fuel economy will result when you approach 1750 rpm for a stock engine, but while not exceeding 60 mph by much.
if you can put the 35's on, drop the body couple of inches, make them really skinny to help rolling resistance decrease, and pump them to 90 psi, you'll have a funny looking truck that gets better mileage.
