97 ranger wont start, has spark and fuel
Old 04-27-2008, 03:06 PM
devilman13xx's Avatar
devilman13xx
devilman13xx is offline
my buddies truck died on him while going down the interstate. its a 97 ranger 3.0 auto.
we had it towed to my house thinking it may have been a frozen a/c comp.
anyways after realizing it wasnt that i checked the fuel pressure and got 40psi while cranking.
i hooked up an inline spark tester to the driverside middle plug and it lit up.
we tryed spraying some starting fluid into the intake and it shot out a huge flame after cranking for a bit.
im thinking it the timing chain but im not a ranger expert so i figured id ask some.
Old 04-28-2008, 08:29 AM
waynebo's Avatar
waynebo
waynebo is offline
I have a post below you,,Won't start,,same problem,no answer yet..i'm thinking maybe cam position sensor. but i read somewhere that it should still run off the crank position sensor so i don't know,,wayne
Old 06-27-2018, 01:21 PM
JoseAvilez's Avatar
JoseAvilez
JoseAvilez is offline
Do you fix it? i have the same issue, spark, and gas, i already change the ECU and has the same problem crank but not start.
Old 08-08-2018, 11:30 PM
Tommy Patterson's Avatar
Tommy Patterson
Tommy Patterson is offline
Sounds like if you put starter fluid and it took a while to shoot flames you are not getting air flow Google comen ranger problems that cause and a list of what it did you should be able to get a answer. Mine did that and it was a fuile pump replace it 3times and then egr probs started. Got it running but still need to replace the egr sinser
flipper8787
1997 - 2003 F150
07-21-2015 07:45 PM
goofy3392
1983 - 2012 Ranger & B-Series
19
07-01-2012 09:55 PM
davidsheets
3.0L V6
06-20-2011 01:05 PM
Paul T
06-18-2010 12:57 PM
bmxstreet15
18
06-29-2009 08:09 AM
Quick Reply: 97 ranger wont start, has spark and fuel
