6.7 Spotted Undergoing Testing.
That hood has to just be temperary. Look click on the closeup picture of the front end, and look at the gap between the hood and fenders on either side. The gapping is off a bit. Hard to tell what Ford will do next. Hopefully they will stick with this 6.7. Too many engine changes the past few years.
Well I hope they do better than the 6.0 did when it first came out, or the first few 6.4 diesels that came out, But they will never get any mileage if the EPA keeps choking them down with emissions crap, I don't understand why we can't take a torch and cut all that crap out, but I'm sure they got it where the truck won't ever run at all if you do that.
7.3 was off to a bad start when it first came out and the 6.9 had problems too. I had a 95 7.3 turbo and it had problems, had a 96 PSD and it would release the surpintine belt when you let off the thottle....pulleys were not alligned just right.
That seems to be the problem. If you decide to wait a couple of years to let the bugs get worked out then Ford has already switched to a new motor and your back to waiting again. It's hard to believe the 6.4 will only be offered for 2 model years.
the hood has been photo shopped..... you can see where they made the shadows too dark on the ridge lines of the hood. and if you look above the drivers side headlight you can see the little piece of the hood that is hanging down from where they didnt line their pasted image up right......very poor photo shopping job if you ask me.....
#28
These trucks are worked on all the time when testing new engines and such. Holes are drilled for sensors and such, pieces may be unbolted on the spot if its affecting engine operation, which is why all the body panels are loose like that.
#29
--Ummm...No. Thats a piece of rubber weather stripping
blow the picture up and look at it. you can see a very distinct white box that has been pasted over the hood. directly above the drivers side turn signal. i have NEVER seen a shadow that has a perfect box shaped white spot in the middle of it. compare the shadows on the hood crease to the shadows on the rest of the truck(right above the cab steps if you need an example). it isnt even close. if you think the shadow in the hood crease isnt photo shopped, i challenge you to find one for me in nature that looks like that.....
#30
