Diff question
Old Apr 26, 2008 | 09:22 AM
Catsailor's Avatar
Catsailor
Diff question
I have ID'ed my diff via the drivers door label - shows code 45 which is a Ford 4.10 according to the list that I found from a previous post. However, it does not give any other info so I can't figure out which Mag-Hytec cover I would be able to upgrade to. Also, mine does not seem to have any fill or drain plugs. How do you change the gear oil?
Thanks,
Tom
Old Apr 26, 2008 | 09:31 AM
xgatorx1976's Avatar
xgatorx1976
there should be a tag on one of the caver bolts. if not look on the front side drivers side there is a boss that will have a #70 in the center making it a dana 70 , otherwise its a ford 10.5 it should be a ford 10.5.
You could pretend you need parts for your diff call Napa and ask for a ring and pinion, they will have a few? that will pin piont which it is.
Old Apr 26, 2008 | 09:34 AM
Catsailor's Avatar
Catsailor
Any idea how to change the gear oil? I am towing a 44' gooseneck with 2 cars in it and I want to make diff oil change a regular maint. item.
Old Apr 26, 2008 | 09:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks,
Tom
45 = 1990/97 F350 / Sterling 10.25 / 4.10-1 / non Limited Slip / 7400 lb. Rear Axle Capacity
Info source: 1990/2002 Ford Light Truck Parts Catalog / Rear Axle Application Chart / Section 40 / Page 5.
(Parts catalog shows Sterling 10.50 used 1999/ on F250/350's)
xgatorx1976
pull the cover. replace the cover then fill with oil, i would use 85-140 gearlube or royal purple gearlube.
Old Apr 26, 2008 | 09:40 AM
Catsailor's Avatar
Catsailor
Tag says 4.10 10.2 and a few other numbers and letters. Also, I found what looks like a drain and fill bung on the front / drivers side - has a square indent for special tool perhaps. But it seems too high for a drain and too low for a fill.
Old Apr 26, 2008 | 09:44 AM
Catsailor's Avatar
Catsailor
Excellent, thanks for the info. According to an article in Diesel World Mag the Sterling 10.25 is a great axle. What do you all recommend for gear oil and upgraded diff cover?
Old Apr 26, 2008 | 09:48 AM
Catsailor's Avatar
Catsailor
So the little bung I found is really just a fill spot - and that is as high as the oil level goes?
Old Apr 26, 2008 | 10:05 AM
NumberDummy
I'll let the FTE members that own one of these answer your questions.
I haven't progressed past the F150 yet!
Old Apr 26, 2008 | 08:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That is the fill plug.
Fluid should be even with the bottom.
I use synthetic oil in mine 80 90 weight and add friction modifier if you have limited slip.
7.5 pints if I remember right.
A rachet and extension, 3/8" drive will get the plug out.
Old Apr 26, 2008 | 09:06 PM
Catsailor's Avatar
Catsailor
Thanks Dave. I got the plug out today no problem and the oil level was good, but the oil was pretty dark so its getting changed tomorrow. I tow a heavy load and want to make sure the diff stays happy.
Old Apr 27, 2008 | 12:14 AM
optikal illushun's Avatar
optikal illushun
TRV for the gasket, i used mobil one 75-90 full syn when i change mine.
Old Apr 27, 2008 | 05:33 PM
Tom D's Avatar
Tom D
Sorry to jump in on your post but could you tell me about my diff. The driver's door frame says C-5. Don't see any tag on diff. Thanks Tom
Old Apr 27, 2008 | 07:05 PM
Dave Sponaugle
C5 code
4.10 ratio
6250 capacity
FORD Manufacturer
LIMITED SLIP type
Can be found here,
Ford Axle Code Chart .: Articles
Old Apr 27, 2008 | 07:36 PM
Tom D's Avatar
Tom D
Originally Posted by Dave Sponaugle
C5 code
4.10 ratio
6250 capacity
FORD Manufacturer
LIMITED SLIP type
Can be found here,
Thanks Dave
