FE Motor ID
Can anyone point me to a resource for id information? Casting numbers?
My other question is, would I be better to swap this motor out for a 351M? I have a complete drivetrain with the M motor, but am not sure which engine would be best. I plan to use the truck mostly off road, not as a regular driver.
Many thanks
Stacey
Stacey
352/360's have the same stroke: 3.50" / 390 is 3.78."
1968/76 360: Despite several bare block castings numbers, the short block is the same for all: C8TZ-6009-G / Same thing holds true for 390's, all the short blocks are the same: C8TZ-6009-H.
All the 352/360/390 1965/76 F100/350's (and 1965/71 352/390 cars) bare blocks were cast as 352's. Only when finished, can they be something else.
JMO, the only place I'd put a 351M is in the scrap pile.
It's a smogged up terd of an engine, and is very prone to cracking cylinder heads.
The 360 is a destroked 390 so adding a 390 crank and rotating system is easy.
John
Can't imagine why you mention FT.
They were used in the larger trucks and offer nothing over a FE that I am aware of. John
According to the VIN its a 360 but of course I was told it was a 390 when I bought it. I pulled the motor and it has casting that say 352. What is a 352? I have read it has the same stroke as a 360 and it often looks like a 352 is refered to as a 360. So are they 2 different engines?
And if the quote above that they are all cast as 352's how can I tell what I have?
VIN F10ACB46943
Thanks!
According to the VIN its a 360 (
No it isn't) but of course I was told it was a 390 when I bought it. I pulled the motor and it has casting that say 352. What is a 352? I have read it has the same stroke as a 360 and it often looks like a 352 is refered to as a 360. So are they 2 different engines? And if the quote above that they are all cast as 352's how can I tell what I have?
VIN F10ACB46943
Thanks!
Used in cars thru 1967, used in F100/350's 1965/67.
All 1965/72 352/360/390 bare blocks have 352 cast onto them, because all these engines were cast as 352's.
Only when the engine is finished could it be something else.
The FE 360 and 390 engines were introduced in F100/350's in 1968, used thru 1976.
The 360 was a truck engine only, never installed in cars.
The 390 was introduced in 1961, used in cars thru 1971.
What the heck?What VIN decoder did you use that says your truck has an FE engine?
What VIN decoder did you use to come up with the fact your truck is a 1969?
Neither is correct.
This is the VIN you posted: F10 A C B46943
F10 = F100 2WD
A = 240 1V I-6
C = Ontario Canada Assembly Plant
B46943 = 1967 (1967 Serial Number Range: A00,001 thru B82,000)
Where did you get this VIN?
Off the registration (title), or off the Warranty Plate (W/P), located on the left door face below the latch?
If off the W/P, peeps swapped left doors due to damage, forgot to swap over the correct W/P.
Compare the VIN on the registration to the VIN on the W/P, see if it matches.
If the VIN turns out to be correct, your F100 is a 1967.
And...the engine has been swapped, and it could be any FE engine size: 332/352/360/361/390/406/410/427/428, from gawd knows what vehicle.
FE engine - 5 valve cover bolts.
On sale day, 352 & 360 engines magically become 390's.
I grab the folder with all my paperwork and had written that VIN down on the outside for a truck I purchased as a parts donor for this project.
For the information I used the front section of a parts supplier catalog, I beleive it was NPD.
THe correct VIN right of the title is:F10YDF30381
It should be a 1969 F100 3 speed with a 360...at least I think so
IT has been sitting for the past ten years and I finally got around to pulling the motor out.
I have a 302 complete drivetrain out of a 91 mustang I was going to use but I am trying to keep this a low buck parts chaser or even more on the lines of a rat rod if you know what I mean. low buck all the way
Thanks for the fast reply & info
The correct VIN right of the title is: F10YDF30381
I just noticed the above was your first post, so...
Welcome to FTE
F10 = F100 2WD
Y = 360 2V
D = Dallas TX Assembly Plant
F30381 = 1969.
360/390's have the same bore: 4.05"
Stroke: 360 = 3.50" / 3.90 = 3.78"
The following refers only to 1966/69.
First Line: VIN
Second Line Codes for: Wheelbase / Color / Model / Body / Axle / Trans
Third Line Codes for: Maximum G.V.W. LBS / Certified Net H.P. / R.P.M. / D.S.O.
I can decode all this info.
Metal plate on firewall = FoMoCo "buck tag" installed at final assembly.
"Numbers matching" on engine/trans parts is a GM thing.
1968/76 360/390: There's no way to tell one of these two FE engine apart without measuring the stroke.
All FE engines from 1958 thru 1976 look pretty much the same.
All 1965/76 FE engines look identical.
The 390's crankshaft, connecting rods and pistons are different than 360's use.
Everything else, including the block, cylinder heads, valve train, rings, rod/main/cam bearings, camshaft, oil pump, timing cover, timing chain & gears, waterpump, intake/exhaust manifolds, gaskets & seals, yadda...yadda....yadda is the same!
The A/T flexplate is the same for all 1965/76 352/360/390 engines, with either a C6 or the 1965/67 C-O-M. This includes the 1965/71 cars with 352/390's.
1965/76: The 352/360's use an 11" clutch, the 390's a 11 1/2" clutch. So the 352/360 flywheel is different than the 390's. This also includes the 1965/71 cars with either 352 or 390's.
