Headlights
Old Apr 23, 2008 | 07:58 PM
micbur54's Avatar
micbur54
Headlights
Hey guys this is my first post .Love the forums and my ranger.1997 xlt 4.0l and 4x4
I'm getting new oem headlights from
KOOL-VUE ORIGINAL EQUIPMENT STYLE HEADLAMPS - JCWhitney Auto Parts
Need tips on removing old headlights and installing new.Do I need to remove the grill? any info will help.
Old Apr 24, 2008 | 06:16 PM
Peter94's Avatar
Peter94
Remember to aim them after you are done.
Also welcome to FTE
I would suggest getting a drill with a screwdriver bit in it. There are alot of screws to take out.
Old Apr 24, 2008 | 07:40 PM
wendell borror's Avatar
wendell borror
Welcome aboard, gald to have you on the ranger forum, you will gain alot of friendships and advice here. Also won't be long before your helping others. I've had 6 rangers and the only one that I ever had to change a head light in was my 84. If I remember correctly, it just had one of those square retaining rings, you on screw that and it let the head light fall out. My 04 you just reached in behind the head light and twist the bulb socket and just take the bulb out.
Old Apr 24, 2008 | 07:52 PM
Bikeitswift's Avatar
Bikeitswift
On my '02 (and was the same on my '97 F150), you slip up the two flat bars behind each light (from above in engine compartment). On my '02 you remove a small plastic panel first (2 screws). The lights just come out (may fall out, so watch it!)
