OK, so this weekend I can no longer signal... Flashers work, fuses are OK, just no turners! When I flip the arm, I can hear the flasher unit try to activate, but it no worky. Any ideas?
had a brain fart, wrong rig there is only one flasher. the turn signal is available eather from ford our national parts depot, and i'am sure from others.
No I think ONO is right. I am pretty sure there are two flasher units. One on the front side of the Fuse panel and one on the the back side. I can't remember which is which but there are two.
Tim i went out and checked, the second one is right behind the fuse panel. If you get down on the floor and look up behind the fuse panel you can see it.
The other thing to check are the bulbs to make sure they are all good. If they go out, flashers will not work at all. Easy way to check this is to try hazards, if the hazards work it is not your bulbs. 9 times out of ten it is your flasher that is going bad, and I believe it is the one behind the panel.
I think i found it! http://npd.dirxion.com/Main.asp
I cant link you directly there, but search 13350-3, and you can see it in the catalog.
Will be on page 125
Is this a relay, or ??? i think i have a similar problem.
My blinkers will blink, then go to really fast then just stay on.
Hazards work fine...
That is your flasher unit for sure because that happened to me a couple of months ago. Open your fuse box and it is the big round silver thing. FOMOCO sells them for just a couple of bucks. Thats where I got mine because I drive past the local dealership every day.
