Offroad & 4x4
STGs Minions general purpose thread Mk XI
  #76
Old 04-21-2008, 07:30 PM
STGFordCrazy04's Avatar
STGFordCrazy04
STGFordCrazy04 is offline
Karl,
hows the mota' coming?
  #77
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
Originally Posted by quadzjr
What the hell rookie!!!!.....you'll never get that beast on the trail again.....hahaha j/k
i finished the bends i just have to get a new arm machined out for me.
-cutts-
  #78
Old 04-21-2008, 07:36 PM
STGFordCrazy04
what does your final design look like fishy?
  #79
Old 04-21-2008, 07:38 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
Originally Posted by STGFordCrazy04
Matt,
twin stick the 205 and put it in high range for 1:1 front digs without the trouble/cost of the doubler.
I dont know why but I wouldnt mind doing a front wheel burnout in front of some 16yr olds
I know, I just have the range box already and would like a cheap way to use it....
  #80
Old 04-21-2008, 07:41 PM
STGFordCrazy04
Personally Id sell the range box to someone junk the back half and use the money for a front drive shaft
  #81
Old 04-21-2008, 07:50 PM
fishmanndotcom
well since this was my b-day weekend, i didnt get a lot done. basically just eff'd up my bender but not before finishing the hoop. i have ~17" of straight tube to mount the ram on, only need 13 so i have 4" of margin. the driver side will weld to the cast spring perch, pass side to the axle tube, and in the middle i will use a piece of 1" plate steel in the middle to keep everything rigid. getting all the measurements and angles figured out so that i can place the ram just right is the next step. i did get my new pump mounted and will hopefully get my steering valve welded on soon so i can start thinking about hydraulic lines.
-cutts-
  #82
Old 04-21-2008, 07:53 PM
STGFordCrazy04
Still worried about welding it to the top of the pumpkin?
  #83
Old 04-21-2008, 07:54 PM
fishmanndotcom
no not worried about that, i just dont know where my ram will place the tubing after everything is figured in.
-cutts-
  #84
Old 04-21-2008, 07:58 PM
quadzjr's Avatar
quadzjr
quadzjr is offline
just another Rockwell looser
sweetness........post pics man
  #85
Old 04-21-2008, 08:02 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
I'm a pack rat and don't like to get rid of parts that are usable. I finally threw away my spider gears from the D44. I replaced my transmission pan after I F_ed it up, and spend two days straightening everything out and cleaning it up, and now it's sitting in the back yard.
But since the subject is up, what are Range boxes going for?
I've tried to look before, and it isn't much.
  #86
Old 04-21-2008, 08:06 PM
STGFordCrazy04
complete 203s dont usually go for as much as married 205s but the range box alone should be worth $75-100 since its the desireable part.
  #87
Old 04-21-2008, 08:15 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
I don't know how much the range box weighs, but I'd say no less than 80 lbs, if not closer to 110ish. That would be fun to arange shipping.
Depending on what kind of job I get in a few weeks, I'll have time and money to work on/finish the Bronco.
$85 or so would kind of help.... anyone interested in a 203 or just the range box.
  #88
Old 04-21-2008, 08:32 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
crazyredneckanyhow is offline
id liek to have it but cant come off the cash now. I know where a whole case is so i might get it for a freebie
  #89
Old 04-21-2008, 09:23 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Tre-E_Ford is offline
It would cost more than $450 to ship you a 203 and 205. IIRC a 203 weighs 300lbs and 205 weighs 150lbs+
yup just kidding, i'll find some for cheap/free and maybe design an adapter, if its possible, i'd sell them for cheap, i want to start a business, and if this is what people want, i'll do it.
  #90
Old 04-21-2008, 09:53 PM
countryboy116's Avatar
countryboy116
countryboy116 is offline
hey yall i need a welder and i guy offered this one too me, i talked him down to $150 over the net already but dont know, its a mig but its one of the welder that only used flux cored wire i guess and doesnt use gas, ive heard these are harder to lay a good bead on and get a strong weld, is this true, what yall think about it i wanna start gettin some practice welding (gunna be makin tree stands and sellin them over summer for extra money) what are yalls thought on the welders that dont use gas?
Chucks Trucks Forum :: View topic - welder
Quick Reply: STGs Minions general purpose thread Mk XI
