Blue clip on the fuel filter line
I was crawling around under my truck today and was looking at the fuel filter lines.I noticed the blue clip on the entering side.Are you to just disconnect this clip and the fuel line releases? I see the leaving side has the normal "duck bill" connection,where you must use the release tool to get it off.
STOP.....................................There are two types of clips.
The blue clip is a 2 part clip. You will see a small piece in the middle of the clip.Lift that up.The with you 2 fingers,push down on the outsides of the clip and it will release the filter.
If it is the other clip that looks like a half moon, the just push the line into the filter.Push on the half moon and pull back.
Don't use the fuel tool as this can wreak the plastic lock inside causing the line not to hold onto the filter.Breaking these clips(which is easy to do) will cost you to replace a line since Ford does not have (or will sell) the clips by themselves.
WishIhada7.3
1999 to 2016 Super Duty
23
10-12-2015 12:30 PM
Blowinsmoke
09-27-2009 05:18 PM
