Windshield cowling wont stay down.......
I certainly wouldn't pay Ford to fix the problem. If under warranty thats one thing, but I was out of warranty when I noticed it. It still wouldn't even be near worth my time and effort to have them fix it. The less than 1 minute it took to screw it down and you cant even tell unless you are looking for it, makes it a no brainer...but to each their own.
Think I'll do it myself.......
Hi, Yep, the glueing down seemed to work.... NOPE it came loose, well you know the 1/4 inch pop up that the driver side piece does...oh well-- I think I'll do this screw thing to secure the cowling is it a hundred 100% effective meaning it's holding up so far no issues since the screw was drilled in? Also how far do you take the screw in? Halfway, or all the way down to plastic's, I just dont want to cracked the plastic by going to deep. Thanks for all help, also it is such a minor thing that I like the screw thing plus it's not noticeable, and want to go there and complain about minor thing that I can do to fix. What size screw and just any crew will work? I have hundreds of screws and just want to make right sized used.
Screw seems to work, noticeda bad clearance with hood to cowl though......
I put a screw in and well it seems ok we will see, I went to deep and screw came through bottom plastic thing no biggie I guess as you can't see it unless you kneel down to look up under the weather stripping, while messing with this cowl I noticed that it's not good fit around the hood when it's shut seems I have more room from hood to cowl on the drivers side then I do on passenger side, any body's like this? Can someone post pic's of the entire cowl on there's? Thanks
My local lazy a__ Ford dealer just ordered a new piece and it popped up before I got home. This is what drives up the cost of a new vehicle _ "I'll just replace the piece - it won't cost me anything" attitude of dealers. I took it to another dealer who fixed it by moving the passinger side piece over.
#28
#29
Well screw didn't hold at all cowl popped up, noticed on the way home from work so...scratches head......I put it like in the picture and well the screw went in straight down. Should it had been put in on angle, instead of straight down? I followed the picture as far as where but I think I went down more then in. Should I pull the screw and try to angle it? Or should I put the screw right in the middle of both pieces in the gap? Thanks
#30
