Could crusie control be added to a truck that never had it?
sure it can be done, anything can be done.
If you want to go stock then you would need the steering wheel the throttle connectors etc. etc etc.
or you could go to JCwhitney and buy and complete aftermarket kit and have everything plus tech support from the supplier.
AUDIOVOX ELECTRONIC DASH-MOUNT CRUISE CONTROL - JCWhitney Auto Parts
If it were me I would go aftermarket.
You will need too much stuff to go with factory cruise. But I think you can get them as a kit. Not sure about the steering wheel etc. The audiovox is around 100 bucks all the rest are 300 plus. I have the audiovox in a metro it works just fine. And its real simple, a switch assembly, the wires, and the servo which has the electronics in it, and the cable. And real easy to install. Good value for the cost.
Cruising along... go factory!
Your 96 should require only a horn pad change and the installation of the servo assembly that attaches to the top of the left front fender-just outboard of the brake booster/master cylinder assembly.
The wiring should already be there with a jumper plug which will need to be unplugged from the connector that is part of the underhood wiring harness. Plug the servo assembly into the harness and attach it to the holes that are already in the inner flange/lip of the fender. Carefully route the actuator cable over to the bracket attached to the top of the upper intake where the throttle cable is already attached. There is a second hole/slot into which the cruise cable outer sleeve can be fitted, but only after the end is attched over the end of the throttle linkage.
Your original horn pad can be popped off of the steering wheel; revealing the horn wiring that can now be disconnected. Install your new cruise-capable horn pad by first connecting the wires to the connectors on the steering wheel. Then snap the pad into place & go for a cruise!
Shop around at your local yards & you should be able to get the needed parts for under $100. Hopefully, the dismantlers at those yards refrain from the indiscriminate use of those nasty sidecutters & bolt cutters! Should you come across some of this carnage, you may want to snag the bracket that the servo attaches to and use it with a servo from any of several other FMC models - car or truck - since many (if not all) share the same length cable.
Also of note is that servos from 1994+ F150 & Bronco airbag equipped vehicles are interchangeable with those from non-airbag trucks. All 1992+ non-airbag trucks are candidates as donors for this project. However, the 1992 models still used the earlier style servo.
dn.
dn.
Thanks all! This definitely sounds like a do-able project.
Looks like I need to go hunting for some parts, and if I have no luck will look into the aftermarket.
One question I have is will anything affect the drivers side airbag on my F350? Need I worry about the bag going off while I work on the wheel?
Donnor, since your rig is close to mine in year, would you be willing to shoot a pic to where and what I'm looking for to pull?
I have a manual, but custom pics are always better.
Thanks
Thanks
dn.
dn.
Bringing up an old thread because it's all I have found that gives me clues about REMOVING the cruise control. Connor speaks of a "jumper" plug in the plug into the servo. Is that truly jumping leads in the harness that need continuity in the absence of the servo?
Removing because it's in a 5 speed truck and will never get used. It's a 1997 project f350 crew that seems to have had a series of previous owners that did not do it any favors, CC is in-op and missing pieces otherwise.
Thanks for any help.
