Bet ya can't fix a starting Problem No one has been able to figure it out yet!
I have a 1995 F-150 ext cab, 5.0L 302 4x4. I shut it off 2 months ago and it has never started since. The truck sat since the end of 2003. I put gas and a battery in it and it started right up. It started 4 times after that. Then I shut if off and it hasn't started since.
I have went through and changed the oil and filter, inline fuel filter, cap, rotor, fuel pressure regulator and plugs and wires. There is spark going to the cap and to the plugs. I have checked/replaced the ICM (remotely mounted on drivers inner fender not on distributor), coil, magnetic pick up coil (stator) in distributor, swapped PCM/EEC with a different one and still no luck and also replaced timing chain and gears. I have also checked all the fuses and relays in the power box under the hood and in the truck to no avail.
I have checked the timing on it and it seems to be in correct time. I have 35 lbs. of pressure on the fuel rail at the shrader valve. I can hear the fuel pumps from both tanks when I switch them so I know the inertia switch is working. I have fresh gas in both tanks (10 gal & 5 gal.) IF I hold the gas pedal to the floor and let it roll over for an extended time it will start to fire like it is flooded or out of time. I have even sprayed ether into the throttle body and it wont fire or start even for a second or so doin that.
I am at a loss for words at this point. Everyone that has looked at it has been stumped so far. I have no way at this point to trailer/dolly to a shop anywhere.
My guess would be the ignition module. I can still remember the frustration my mechanic had tracking it down. Here is the link to my post. Take a look and see if it is something that can help. Good luck.
https://www.ford-trucks.com/forums/6...l-not-run.html
I haven't checked compression on cylinders. Some of the plugs are wet others are not. I dont have the ignition module on the side of the distributor. Mine is remotely located on the side of drivers side fender. I have swapped it out with a new one and still no luck. I also had the old one tested and it tests out good.
I know you replaced the cap and rotor but you may want to take another look. Also, it is easy to misroute the wires. I am sure they have been checked before but just for peace of mind, tripple check them. Could be a short in the ignition circut so the coil is not putting out the proper voltage?
I read all the replies and clearly you addressed the ingintion module which was suggested a couple of times. A truck that don't run is no fun and basically useless. You can replace enough parts and still never know what the culprit was. I think at this point, I would be looking for a good Ford mechanic and a tow truck.
Have you checked any of the fuseable links? It's got to be something simple.
Tim
Tim
