83f-150 351 Questions
Earlier today I looked at an old rusting 83 F-150 4WD with a 351 and a four speed that a fellow has for sale. My interest in it is the chassis and drive train. I want to use it in a 53 F-100 shortbed I am building. I have questions about the engine. If I remember correctly, Ford was using some kind of electronics on their engine at that time but I don't remember much else. I didn't spend a lot of time looking at the engine because I was also dealing for two other trucks with the same guy. I am wondering if anybody knows which 351 Ford was likely to have put in the 83 truck. I would like to build it up and go conventional on carburation and maybe basic pointless electronic on the ignition. I also would like to do a complete rebuild and go with some moderate performance enhancements. With this in mind, I would like to hear some opinions and ideas regarding the engine in this truck. Years ago I had a 351 Windsor I put in a 67 Ford Galaxie 2DHT that was stock but seemed to perform quite well. The old 351 Windsor was a small block that was basically a 302 block with the cylinder tops being a bit higher and requiring a little bit wider intake manifold. The heads were the same as a 302. I have never had any experience building or owning the other 351 versions. If anyone knows what engine this is and/or has experience building and running it, I'd like to hear from you.
Dave
Dave
Dave
When I said fuel injected, I meant factory fuel injected. Starting somewhere in 85/86, they came fuel injected from the factory. You would need to get all of the stuff from a donor truck.
I too am old school (and not a "youngster") and although a carb is easier to work on, the same displacement motor is much more efficient and can make more power when injected.
If you are going to stick with a carb, you can do a lot more to the engine with regards to heads, cam, intake, headers and etc.
Summit Racing and Jegs are good sources for inexpensive after market parts.
When you look at it, see if the distributor on the engine has a vacuum line connection. If it doesn't, then it does have a lot of electronics on it, and it also may have a variable venturi carb. All this doesn't matter if you are going to a 4 bbl anyway, but if the dist has a vacuum line, you can keep that system (Ford duraspark II, which is a good system) and not have to buy another ignition system.
Uncle stosh probably knows more about it, or looked it up, but 1983 is going to be very close to the transition year from the 351m to the 351w. If you want to make double sure you have a 351w, it should have 6 bolts on the valve cover. The 351m has 8 bolts holding the valve cover on.
You are correct about the 351w being closely related to the 302, and it has lots more potential than a 302. On all Fords, the heads are the worst part, so if you could swing an aftermarket new set of heads, it will really wake it up then.
I am assuming you are going to get another tranny, unless the old pickup is going to be 4wd?
Thanks for the reply. I bought the truck today and drove it home. All things considered it was better than I thought it would be. the Body is pretty rough but all that is going to the crusher when I get around to taking it apart.
I started a thread here because of the year model of this donor truck but I will continue the discussion of this project on the '48 to '60 forum as it would be getting off topic a bit for this forum. I do appreciate the advice though.
As for the tranny, I plan on keeping the four speed as the low gear and rugged construction will serve my puropses well as I intend to use the truck as a novel looking shop truck with my restored Miller Big 40 welder in the back and the 4WD to get it where I need to go. Beefing up the 351 is just the frostring on the cake.
I won't be scrapping out the body for a while if anyone needs something from it. I will soon post pictures of it on my shop web page which is http://www.wfmservice.com which also has my contact info. I really hate to toss something that has value to someone else. On the other hand I am up to my neck in junk here and something has to go. If anyone is interested in continueing to follow the project on the 53 go to https://www.ford-trucks.com/forums/7...ml#post6027329
Once again, thanks for the reply.
Dave
If you have the money, the aluminum edelbrocks are a nice choice. There are several other companies, I think one is air flow research. The good thing about the aftermarket heads is they already have the large valves like the some of the chevy heads, and they have guide plates and a adjustable valve train. This means you can put any cam in the engine, and be able to adjust the valvetrain without any "kits".
I believe there are some cast iron heads out there too. Look at jegs or summit racing.
Dave
You will really have to strengthen that old frame to take the 4wd stuff. I had a 53, and with the leaf springs and front solid axle, it's not a very strong frame. Take a look at the front crossmember on the later model truck. It's huge, and supports the axles as well as the front coil springs. It might be easier to get an older front straight axle out of a 70's pickup.
As I mentioned earlier, this thread tends to be a bit off topic and I have tried to take it to the 48-60 forum because of the year of the truck. I originally started this thread to learn what I could about the 83 donor truck. I only continue here to respond to important and interesting points like the ones you have raised. Thanks for your response.
Dave
dave.s3693
16
08-18-2012 01:48 PM
first today
10-27-2009 07:37 PM
abninf87
09-20-2009 08:36 PM
