So, have you pulled a truck with a TowBar? (Clint/AJ-etc, step on in)
I rigged up Clints Towbar to the project truck to pull it around in front of my shop, but I need to back it in to start on the rear shackles.
How well can I back up using a TowBar? I/e can I negotiate turns (while backing)?
I don't want to get out in the middle of the road and get in a pickle...nor do i want to leave the Thumper sitting across the street
I won't be moving it until I hear back from one of you "towers".
EDIT:
Heck, can't edit the main titles spelling goof...
EDIT:
Well...that would work if...
We had a steering box installed, and if we had it all hooked up
Unfortunately, we have niether...just a front axle with the tie rod hooked up.
Damned Dan...it's all his fault!
Cool, so she'll track okay backing on turns? If so, Thumper will be in front of the shop in a few hours
on
Umm...you can't really back up with a towbar. It just doesn't work the same as a trailer. You can sort of back up in a straight line for a short distance, but it's damn near impossible to make it steer as the whole premise of towing with a towbar is to take advantage of the caster designed into an automobile's steering to make it track straight. Doesn't work when backing up...
Didn't get a chance to try yet, the irrab\gation water was running fast...
Soooo, seems we have a vote for and a vote against. Maybe tomorrow I'll tr'll try a wide swing with the tractor and see if I can get it angled in, was going to use the PU, but might need a sharper turning machine.
What the heck, nothing ventured, nothing gained.
Well, Dan get's the nod on this one...took me about 45 minutes of fighting it with the tractor, just to get it somewhat in line with the carport...so went and got the forklift and manuvered in front of the shop.
Makes me really want to get the old rubber tired lift I have out back running for stuff like this...maybe will have an "NC FTE put-the-forklift-together-meet"
