Lowering a 2WD 1994 F150
  #31
Old 10-23-2008, 12:58 AM
injville
injville is offline
injville is starting off with a positive reputation.
lean
mine leans to the drivers side. Whatever you do don't heat the springs or try to remove leafs, I have friends that have spent more fixing stuff that gets screwed up that way. Do it the right way, have a good alignment shop set it up and there will be no worries.
  #32
Old 11-07-2010, 06:58 PM
rcruz's Avatar
rcruz
rcruz is offline
rcruz is starting off with a positive reputation.
THATS A NICE LOOKING TRUCK NINTY4F150
  #33
Old 11-10-2010, 11:20 AM
john410312's Avatar
john410312
john410312 is offline
john410312 is starting off with a positive reputation.
Here's mine...
  #34
Old 12-01-2010, 07:49 PM
rcruz's Avatar
rcruz
rcruz is offline
S&S SYSTEMS I WOULD LIKE TOO SEE A PIC OF YOUR TRUCK I HAVE A 1994 FLARE SIDE THAT I WANT TO LOWER BUT I DONT KNOW HOW LOW I WANT TO GO I WANT TO SEE HOW IT WOULD LOOK WITH A 5" DROP ON THE FRONT
  #35
Old 12-04-2010, 10:42 PM
armycain
armycain is offline
armycain is starting off with a positive reputation.
I'm Dropping my 95 with a 3/5 but before I do I'm curious of what kind of clearance I'll have I have to go over speedbumps and I don't want to grind on them everyday any help would be appreciated.
  #36
Old 12-04-2010, 11:04 PM
rcruz's Avatar
rcruz
rcruz is offline
i dont know iam trying too find out my self. i want too drop mine. sorry i cant help
  #37
Old 12-05-2010, 11:18 PM
86F150302's Avatar
86F150302
86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
No problem going over speedbumps.
Here is a picture I had after I dropped my 86 with a DJM 3/5 drop. Picture was before alignment so excuse that. (235/60/15 tires)
I think the radius arm brackets are the lowest point of the truck. I measured for someone on here a while ago. Ill see if I can find the thread.
Here is a video I have of it. You can see how much clearance you have with the 3/5.
http://www.youtube.com/user/popwarho.../3/7zPjG8D_YQI
rcruz : I would not recommend 5" drop on the front. Going to be hard to get aligned and only going to have like 1 inch of suspension travel. You will also need a pretty big C notch in the frame in the back for 7" of drop if you do 5" in front.
  #38
Old 03-05-2013, 08:33 PM
froosen123
froosen123 is offline
froosen123 is starting off with a positive reputation.
Originally Posted by TexasGuy001 View Post
Dan91ford150,
Just get a set of 2 inch drop shackels. They are about 30-40 bucks. That is what I am going to be doing to mine. Its much easier and you retain the factory payload.
Where did you get your 2" drop shackles?
  #39
Old 03-06-2013, 02:52 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I don't actually have them on my truck. I have front leveling springs to raise the front to make it level. I do know a few people that have the rear lowering shackles. I think Ebay may have the best deal on them.
  #40
Old 03-06-2013, 09:05 AM
froosen123
Thanks, just ordered them. I'll post before and after pics when I get done.
  #41
Old 09-14-2013, 05:49 PM
RobErnst
RobErnst is offline
RobErnst is starting off with a positive reputation.
Any pics yet?
  #42
Old 09-13-2015, 06:43 AM
angelrdz
angelrdz is offline
angelrdz is starting off with a positive reputation.
What about a 6/8 drop. Yes 6/8.
I have dropped many of my friends c10's and now I want to drop my 96 f150 Rwd XLT I have some 22" rims on it. It's a cammed out 302. And it's just a street truck. But I know you can cut the springs on the front like a regular spring then you just grind down the edge of the top of the coil so you can bolt it back on. But I'm looking for some spindels that will drop it about 3 inches. And I can do a 7 inch flip kit in the rear and add in a 1 inch lowering block in the rear. My 22"s actually lifted my truck which is why I'm going with a 6/8
  #43
Old 07-12-2017, 03:12 PM
armando frausto
armando frausto is offline
armando frausto is starting off with a positive reputation.
Originally Posted by nintey4f150 View Post
i got a 4/6 drop on my 94 f150..... belltech beams with one inch drop springs and a belltech flip kit in the back... and no you cannot cut the springs on a 92-96 f150
http://i138.photobucket.com/albums/q...7/truck007.jpg
What shocks did you use on your truck all the way around? Thanks
  #44
Old 07-13-2017, 01:52 AM
raystankewitz's Avatar
raystankewitz
raystankewitz is offline
raystankewitz has a good reputation on FTE.raystankewitz has a good reputation on FTE.
You know, the last post before yours was almost two years ago and these people have probably moved along to other things. In the dark blue band above each post window has the post date over to the left side.
Just thought you might know.
BTW, most drop kits can be bought with shocks that fit/work or the kit will tell you what shocks to use.
  #45
Old 07-29-2018, 12:36 PM
Kelsey Daley
Kelsey Daley is offline
Kelsey Daley is starting off with a positive reputation.
Dan91ford150,
We have a 93 f150. Where do we find a good set of drop shackles that you mentioned? Interested to see how that would look when done.
Quick Reply: Lowering a 2WD 1994 F150
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
