Down and Dirty on D3VE head porting
#31
Monster,
Yeah, I sort of left all that out because this is just a budget build for this year, and for now I am going to run the stock size valves (read=lack of $$). Next year when I can do the stroker, this all will be changed out, and I will be looking into a totally different set of heads. BTW, this is for the ranger mudder I'm building, if you haven't fugured it out...
#32
Here are some pics of my Weiand Stealth that Kris asked me to get. They show the simple casting flash removal and my quicky VHT 1200 deg paint job to cover the ugly, as this was a used intake and even after cleaning it has some dicsoloration in the aluminum.
Under the carb pad, just removed casting flash:
Runners, matched to the intake gasket (like the heads), and removed as much casting flash as I could all the way up to the carb pad:
#36
Karl,
email the links to them in your photo bucket if you dont mind.
STGCountryboy312@aol.com
Georges motor comes out tomorrow!!
#37
Karl, great thread boss!
I am a Novice in the porting world at the moment (I should have searched earlier), this helped me out some in the exhaust area. Thanks. I have read quite a few threads & articles on porting thus far but nothing really for D3s until now.
Did you try more than a standard 3-angle valve job? or top-cuts & back-cuts on the valves?
#38
Jim,
I followed the guides I got from Scott Johnson. He's a head porter out of Washington state. Do a google search for re-incarnation.com or check the 460 sites. He has the step by step instructions.
Now for my valves, when I 1st did the heads I had a good 3 angle job done with the stock valves, now I have the ford motorsport valves, with an increased bowl area and another 3 angle job. The angles are not "standard" angles though...
#39
Jim,
#40
#43
dukedrummer89
39
01-06-2016 08:58 PM
SCRebel
62
02-18-2013 11:47 PM
Rellim51
31
07-19-2011 09:38 PM
mobilefleet
1983 - 2012 Ranger & B-Series
03-29-2010 11:10 PM
