what all is needed to hotshot....leagaly
its not somthing im looking to get into full time, but maby somthing for an occiasional free trip somewhere iv never been too durring the slow season and maby make a buck or two in the process. also would i have to attach dot or mc numbers to my truck, if so would i have to stop at all weight stations even if im hauling a personal load or not hauling anything at all
to do it leagaly you would need dot #s and stop at the wiegh stations every time you pass one.You will need to do annual dot inspections and keep records of them and repairs on you truck. You will be open to road side spot onspections also. You will need to make sure your insurance will cover you.
would you be able to attach dot #'s magneticly so they could be removed when not working, or maby a sign in the window saying not in service or something along troughs lines. also what class of cdl is required? and about stopping at weight stations im talking about when im not hauling a hired load. that would be kinda a pia to have to stop every time i pass a weight stations when only occasionaly hauling hired loads
you also better have a one ton if you plan on pulling a trailer, 3/4 you will be over the GVWR pretty quick.
what state are you in??? the state to state laws differ but the basic Fed regs are pretty easy.
here is a link to the Federal Motor carriers website. they will be the ones you have to abide buy when it comes to truck inspections, weight limits, tags on truck and trailer, your personal liscens, insurace stuff. being a 2nd year trucker with my own Authority, its a VERY steap learning curve. rules regs, taxes, paperwork, logs, where your legal, where your not..........
Rules & Regulations - Federal Motor Carrier Safety Administration
there web site can be very confusing, go slow, read and reread again.
feel free to PM me if you want with any other questions, I will try to answer as best I can.
Diesel Rod
its not against the law to weigh more than what you are rated for, but is not recommended. I'm in MI and use magnets with company name, City & state and DOT #. I pull a 16k load with my F250 and am just under 26k weight RATING, not gross weight. If your over 26k GVWR you need a cdl, if not, just a chauffers license. I had to get a commercial plate for my truck as well.
see what I mean, CONFUSING.
Diesel Rod
Thats why you just by an apportioned plate, then they LEGALLY have to abide by what the plate is rated for. Here in ohio, you need MC numbers, or puco, plus you have to tag everything COMMERCIAL, and it doesnt matter if your hauling your own things, or someone elses, YOU HAVE TO STOP AT ALL WEIGH STATIONS.
well i finally got a trailer to pll behind my stroke... and hope fully i get some business from drill steel... they haul mining supplies... roof bolts mining belt the teeth for continuous miners you name it they got it... and i am gonna go in and talk to them about hauling for them... and the trailer i got is not as big as the ones some of you all have but hey it gets the job done... and i will post some pics with a load on it when i get the chance...
trailer breaks in proper working order can relay save your ***, i had to panic stop 10k one time with trailer breaks but i never turned them up after hauling an empty trailer, it was a white knuckle sobering experience. now i keep them turned up as high as i can without the breaks locking.
so am i correct that the licence i would need would be a chauffeurs license? what a the difference between a chauffeurs license and a cdl? what are the differances in obtaining eather license?
