The fusebox is in the right hand (passenger) kick panel under the glove box. you have to remove two plastic panels to see the box. Then pull the box cover from the bottom to get to the fuses. Pull your owners manual out and i think its like page 194 or something that has the fuse diagram.
make sure you are holding the manual in a way that the picture of the fusebox matches the way the fuses are actually lined up.
use fuse 104 as a guide (its toward the bottom and kind of long . . . it should also be silver (made of aluminum)
if I'm not mistaken, i think #104 is the fuse you're looking for. I THINK thats the one for the power sliding window
