Code Reader Codes & Problems
Old Aug 25, 2002 | 02:01 AM
Quantrex's Avatar
Quantrex
Old Aug 31, 2002 | 08:42 PM
The Man's Avatar
The Man
Ok First i got a 327 Which Says... EGR Valve Position (EVP) Sensor, Pressure Feedback EGR (PFE) or EGR Pressure Transducer (EPT) Signal Voltage too Low. What in the heck should i check for that??
I also know i have a bad 02 but the Test didnt say anything about that.. Does a bad 02 show up??If the Test Is Performed Right, How good are the Results??
Thanks, Im only asking because somehow i lost 3mpg over the Last week so i figured i could find out what happend..
Thanks again.
Old Aug 31, 2002 | 11:07 PM
Franklin2's Avatar
Franklin2
Look for the egr valve. On the 302's it's over top of the passenger side valve cover up front. It should be round with a pipe coming out of the bottom, and it's mounted to the throttle body. The sensor that is not working is on top of the valve with wires coming out of it. I am assuming the 351w is the same.
Old Sep 2, 2002 | 06:53 PM
The Man's Avatar
The Man
Thanks Franklin,
Should i just replace it or try to Fix? AutoZone wants $100 for a New one so if it can be fixed that would be the way to go.
kbf1961
Oct 17, 2015 10:05 PM
C-700
May 15, 2007 10:48 AM
KCMAGERS
May 8, 2007 12:36 AM
Lashlaroo
Aug 10, 2002 11:39 AM
aerocolorado
Aerostar
Nov 25, 2001 09:36 PM
