cleaning valley
Old 03-31-2008, 09:55 PM
dieselphil's Avatar
dieselphil
dieselphil is offline
cleaning valley
I want to clean up the valley in my 96 psd. I was told I could clean it with simple green, is that the best way? And if so are there things I should cover while washing?
Old 03-31-2008, 10:16 PM
kawa's Avatar
kawa
kawa is offline
Simple Green is good, Brake Kleen is good just make sure that the engine is COLD and DO NOT use pressure. Stay away from electrical connections the best you can. Don't forget to cover your 6637 if you have one. Stay away from the RH area of the firewall and inner fender as well as the main cable connections. You may want to cover the Alternator.
Other than that you should be in great shape. If I have missed anything someone will jump in and add it to your list.
Rog
Old 04-02-2008, 02:43 PM
dieselphil's Avatar
dieselphil
thanks Kawa. I do have the lovely 6637 I will be sure to cover that baby.
