1996 7.3 wont start after sitting 2 days - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Reload this Page >
Old 04-01-2008, 08:07 PM
phatmanmike
phatmanmike is offline
phatmanmike is starting off with a positive reputation.
herez what i know....
1996 7.3 psd turbo
ran out of fuel and let sit for 2 days. returned with 3 gallonns of 4.00 a gallon diesel and put in tank. cranks, white smoke out tail pipe, tach moves, fuel bowl fills up, but will not fire/ start.
towed home, checked fuses, none blown. cranks, white puffs out tail pipe, but still nuttin.....
im in tampa area florida, 80 degrees, is the GP still needed to start when its warm out?
Old 04-01-2008, 09:24 PM
Action4478
Action4478 is online now
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
1996 7.3 psd turbo
If it only ran out of fuel ,,, make sure the batteries & starter are up to it ,,,bleed the Air from the FPR ,,and crank till it starts ...
Old 04-01-2008, 09:32 PM
immastrokinnow's Avatar
immastrokinnow
immastrokinnow is offline
immastrokinnow is starting off with a positive reputation.
check the hpop reservoir. somebody will come along with a pic. but that would be a good place to check.
Old 04-02-2008, 10:15 AM
FARM69's Avatar
FARM69
FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Yep, it will take a little cranking to get the air out of the fuel system. Might also be a good idea to check the oil level in the hpop. There is a hex plug on the top right side I believe.
Old 04-02-2008, 11:22 AM
phatmanmike
its running again!!!!!!!!!!
ok, thanks guys, its running now and im letting it recharge the batts a bit from cranking and cranking.
anyways....
heres what i did.....
i cleaned the screen on the Fuel Pressure Regulator, i checked and filled the oil level in the High Pressure Oil Pump, as it was low, and i also bled the air from the Fuel Pressure Regulator.
it would sputter and spew white smoke, but after about 10 more seconds it gave one big coff(caugh) and started. its idleing now and i hope this could be usefull to anybody else in teh futre.
mike
Tim Hodgson
68
04-29-2018 11:47 AM
wizofnet
02-17-2014 07:59 PM
Matthew Tate
19
08-15-2013 07:43 PM
mercedes4oil
16
02-25-2011 11:51 PM
amubus1972
09-10-2008 09:46 AM
Quick Reply: 1996 7.3 wont start after sitting 2 days
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
