can you use transmission fluid...
The problem I see with ATF is similar to a problem seen with WMO. Either is likely to have extremely small even
sub-micron sized abrasive particles in suspension. Prolonged use of such as a fuel will wear anything it touches at an accelerated rate. That would include the entire fuel system, including injectors, and the cylinder walls pistons and rings.
As Phydeaux said, a lot of the particles are SUB-MICRON........No filter will remove them, yet they are still abrasive. Used tyranny fluid also contains acidic chemicals in suspension that will harm your engine. If you really want to try it, do yourself a favor and send a sample of the oil to Blackstone Labs for an analysis FIRST. Once you see just what that oil contains I'll bet you won't want to use it.................
97f250 7.3 4x4
13
02-10-2015 07:34 PM
Black Cowboy
Bio-diesel, Propane & Alternative Diesel Engine Fuels
25
05-11-2009 07:42 PM
jtownes14
17
05-21-2008 03:16 AM
cjben
General Automotive Discussion
07-20-2007 04:25 PM
