5th Wheel and '98 F150 v6
Hi guys. The wife and I are getting into BBQ competitions and I'm wanting to get a small 5th Wheel trailer (so the wife will be comfortable at comps). My smoker is trailer mounted. Due to state laws, I can't do double bumper pull so I'm going to have to do a 5th wheel trailer. Will my little 4.2l v6 be able to handle a 5th wheel and the smoker? If so, how big of 5th wheel can I go? I would like to go with a 20' - 24' unit as that will provide enough room for us.
Most towing will be in-state so I won't be going really far.
Thanks for the help.
i guess it all comes down to the weight that you want to pull. what setup is your truck? rear gears, auto or standard, cab, bed. after you get me that i will get you the weight that truck is rated to pull. how much does your smoker weight? more than likely you don't have a big enough truck. but if you find a light weight 5ver and your smoker don't wiegh much it might be doable
Originally Posted by crown180
Just picked up an F250 for a fifth wheel camper. Previously had a Silverado with an 5.3 but the problem you will have is the pin wieght. Figure 20% of trailer weight, add wife/hitch/cooler and you will be over your payload in no time.
May want to consider upgrading.
Shwan_89HD
05-30-2014 05:58 PM
sandiegogreg
Toy Hauler Towing; Fifth Wheel & Bumper Pull
02-10-2005 02:38 PM
iradi8
Aftermarket Products
11-25-2002 09:52 AM
