Tapping vacuum lines
Old 03-27-2008, 04:22 PM
ReAX's Avatar
ReAX
ReAX is offline
I finally tapped my vacuum system for a gauge. What I did was take a 3/16" plastic T, the tap side I put on a piece of 1/8" ID hose, slide the 1/8" od hard nylon line from the gauge in to it and used heat shrink tubing to seal it tight.
For the T to stock male fitting, I just a coupler I found on my parts engine, but a peice of 3/16" hose should do well, then the stock female fitting slid right on to the T.
Very nice fit and finish.
