1948 - 1960 - Cootie-Bobbed EFI Systems
#76
So who's got the plans for a flow-bench?...Is that what's needed?.....What parts are required to build a small bench top model do you suppose...Do I need to make an appt. with Boeing to use their wind-tunnel?
Nahh...cram air and fuel into tight space,compress and ignite...cootie-bob-style.
What I'll do is set up the manifold with a calibrated leaf blower motor moving air, set the fuel regulator for 65 lbs have all this, -Flatmotor suspended 4.67 ft above the ground and see if I can impliment the scorched earth polocy within 3 seconds. And I'm talkin smokin roots, I don't need no stinkin flow bench, thats why the Good Lord invented Neighbors.
Did I mention I'm building my own manifold
I get to weld bungs, not just a couple bungs I get to weld a whole bunga abungaload.
#77
I will not get sucked into this thread
I will ....
Dang it now you have me just when I had decided not to bother with the EFI and stick with a simple 4bbl. But boy did I ever enjoy hooking up the laptop and going for a little speed density tuning joy ride around Texas Motor Speedway in the old Caddy CTS-V.
Ok nevermind, I'm moving onto finishing my brakes and body work. Good luck boys.
I will ....
#80
It is a pretty kick **** stand alone computer.
Haltech Engine Management Systems
A buddy of mine used an E8 to control his 13B RX7 with a GT40 turbo on it. He is using the same thing to control the 4.8 V8 that is going in there now. It is pretty slick but it is also a little on the spendy side.
#81
#82
I'm not sure about ease of hookup, but I can't imagine it would be all that hard. Tuning looked to be straightforward. A laptop is hooked up and you can make changes in real time.
Another thing to look at is using the Ford ECU and a Tweecer. You can have 5 different programs that are selectable but you are more limited with that than a stand alone.
#83
I just did a quick run thru of the Haltech System, with the limited RPM range of the Flathead (Non-Racing) the 500 RPM increment adjustments are a bit too wide for my tastes.
I think the application is more for a high rev machine.
I think for the majority of engines that you'll find stuffed in these Old Fords to get the most out of the EFI (Driveability, performance etc) it will be a plug and play with no Off the Shelf System filling all the needs.
Just like the Ol Days, What can I make work, to impress myself.
#84
Found Floating on the Internet.
Ford Multiport Electronic Fuel Injection Wiring Manual
This is the 25 page manual Ford supplies with their Electronic Fuel Injection Main Engine Harness kit. Copies can be purchased directly from Ford Racing Performance Parts. For more information call: 810-468-1356.
The manual covers the following FRPP part numbers:
Main Harness
Sensor and Relay Package
Engine Harness and Controls Package
M-12071-C302
M-12071-D302
M-12071-E302
Below is a copy of the manual mentioned above, this will enable you to view the manual to see if you do indeed need to purchase one.
Ford Multiport EFI Wiring Manual
Main Harness
M-12071-C302
M-12071-D302
M-12071-E302
#88
#90
on
well I have an idea for my next project I using a y block and it has the runners on top of eachother like any others and I'm thinking of using speed density mustang system and stacking runners on top of eachother and putting the injectors on the side and at an angle, the real problem I'm thinking is fuel rail the routing would have to be quit complicated to get everything to work but thier would be alot of custom fabing for intake plates coolant routing sensor, good thing I'm a welder and a mechanic. Plenum box a lot of square tubing and a whole lot of time. Think it could work?
Spktyr
05-03-2017 02:52 AM
bigfootsurfin
06-11-2015 07:10 PM
0ldman
04-07-2015 05:33 PM
akuhr93'f150
09-18-2014 10:07 PM
