2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Break in period for 08' Exp
Old 03-01-2008, 10:04 PM
680276122's Avatar
680276122
680276122 is offline
Question Break in period for 08' Exp
Maybe I'm hard of reading, but I couldn't find what the recommended breakin period is on the 08' Expeditions? I'm guessing that it's 1000 miles, no constant speed for > 10 minutes, no more than 3.5K RPM's.
Old 03-02-2008, 06:22 AM
SemperFiDevilDog's Avatar
SemperFiDevilDog
SemperFiDevilDog is offline
and NO Towing for the first 500 miles...
Old 03-02-2008, 10:15 AM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
I have never followed the break in period after the first 250 miles, after that everything is pretty much good to go. Heck we take our F-550s w/ 8 miles on them and load them to over 22K lbs and run them that way for 80K miles. Haven't had a transfer case or axle fail. Engines crap out all the time but thats the 6.0. I think break in periods are a thing of the past.
Old 03-03-2008, 06:43 PM
R-WEST's Avatar
R-WEST
R-WEST is offline
Did you ever try following some type of break-in procedure? Maybe the engines would live a bit longer. Just curious. The 6.0 certainly seems to have its share of issues, but I've seen some with well over 100K with no problems. Just sayin'....
Old 03-09-2008, 08:38 AM
tseekins's Avatar
tseekins
tseekins is online now
Received 1,221 Likes on 803 Posts
I've always been told to break it in the way you intend to drive it.
Tim
Old 03-11-2008, 01:57 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
from '08 Expy Owners Guide page 6:
"BREAKING-IN YOUR VEHICLE
Your vehicle does not need an extensive break-in. Try not to drive
continuously at the same speed for the first 1,000 miles (1,600 km) of
new vehicle operation. Vary your speed frequently in order to give the
moving parts a chance to break in.
Drive your new vehicle at least 500 miles (800 km) before towing a
trailer. For more detailed information about towing a trailer, refer to
Trailer towing in the Tires, Wheels and Loading chapter.
Do not add friction modifier compounds or special break-in oils since
these additives may prevent piston ring seating. See Engine oil in the
Maintenance and Specifications chapter for more information on oil
usage."
It is really amazing how many people do not read the owner's manual. Who knows why, but it's a fact. The owners manual has almost everything that you need to know about your vehicle. Its a big book, owners paid for it, but it wastes away in the glove box or in the trash. Too bad.
Old 03-17-2008, 08:18 PM
680276122's Avatar
680276122
Rich,
Thanks for pointing it out for me. I did read the manual, and even took the time to find something on the breakin period, but obviously overlooked what you posted. Thanks again.
Old 03-17-2008, 08:39 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
Rich,
Who would have thought that there was no section for it and it was in the introduction? Who reads introductions anyway? Well, me because at NHTSA we were alway ranting about owners not reading their manuals and calling NHTSA because they didn't know why their vehicle did this or that.
I suppose that I am too **** sometimes! I read everything that came with the vehicle and I am part of the way through the shop manual.
Old 03-19-2008, 03:01 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Is your shop manual a hard copy print, or a CD copy? I'd really like a CD copy.
Old 03-19-2008, 03:21 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
Hard copy.
Old 03-19-2008, 05:27 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
Rich, does the manual state normal and maximum operating temperatures?
If you can look it up, I’d like to know about; Cylinder Head Temperature, Transmission Fluid Temperature, Engine Coolant Temperature, and Engine Oil Temperature.
I’ve got a MSD Dashawk monitor and can look at everything except for EOT. I’ve got some datalogs stored in the unit that I haven’t downloaded yet from a travel trailer tow I made last week round trip Phoenix to San Diego.
Old 03-20-2008, 05:44 AM
chuck s's Avatar
chuck s
chuck s is offline
Ford has no OBD2 sensor for Engine Oil Temperature. You'll need an analog sensor.
Head temperature on mine runs maybe 1° or 2° above coolant temperature and that rarely exceeds 200° when towing.
Towing my 5000 pound camper thru the Alleganies in central PA.
No data yet on trans temp other than daily driving.
The torque converter locks in 4th, 5th, and 6th for sure.
-- Chuck
Old 03-21-2008, 07:40 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
The shop manual says nothing about temperature other than using it as a criteria for testing, ie. with the coolant at least 152 degrees, then test the xxx system.
Old 03-24-2008, 08:13 PM
Baumbach's Avatar
Baumbach
Baumbach is offline
The oil from the factory has a dye in it that only shows up while looking at it with a black-light, they do this so any leaks can easily be found. They say the dye will not hurt anything, but in any case I change my oil to full synthetic at 1k miles even though the warranty did not require it until 7.5k miles on my 08. Note: I am using Full Synthetic and not the factory installed Synthetic-Blend, there is a big difference. Oil change intervals went from every 5, 000 on 07's to 7,500 miles on 08's
Old 03-27-2008, 06:27 PM
immastrokinnow's Avatar
immastrokinnow
immastrokinnow is offline
i always say its either gonna go or blow. if it blows....it wouldnt have lasted long anyway. and for you guys you all have warrenties....
Quick Reply: Break in period for 08' Exp
