caustic instead of lye?
Old 03-25-2008, 04:58 PM
jerrytown2001's Avatar
jerrytown2001
jerrytown2001 is offline
can liquid caustic be used instead of lye in making biodiesel or wvo?
Old 03-25-2008, 05:31 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
If you mean Caustic Soda that is the same thing as Lye.
They are both Sodium Hydroxide (NaOH)
If you are getting liquid caustic soda (a NaOH water solution) use it in the titration step.
You should be able to find the percentage of NaOH on the label somewhere then dilute it to .1%.
If there are other chemicals present in the solution I would not use your liquid caustic soda.
Old 03-25-2008, 05:44 PM
jerrytown2001
we use 50% caustic soda where i work. so, i should just add water to bring it to .1%??
Old 03-26-2008, 08:12 AM
Phydeaux88's Avatar
Phydeaux88
Yup
50% = 500mg/ml of solution.
to make .1% add 2ml of your caustic soda solution to 1 L water
Old 03-26-2008, 09:49 AM
jerrytown2001
well the lye is going to be pretty cheap, but the mehtanol is kind of pricey. is there any way to reclaim it.
Old 03-26-2008, 10:14 AM
Phydeaux88's Avatar
Phydeaux88
you can recover unreacted methanol from both the glycerin and BD products of the reaction. In fact it is recommended that you do so as it makes cleaning the BD easier and cheaper plus the methanol can be reused.
BroncoEx
07-01-2010 08:56 AM
MAKO314
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-09-2008 06:14 PM
karljay
Garage & Workshop
09-02-2006 12:18 AM
wbhinton
08-12-2006 07:05 PM
kennedyford
26
11-25-2005 09:05 AM
Quick Reply: caustic instead of lye?
