scary engine noise!!!
Old Mar 24, 2008 | 08:10 PM
camccardell's Avatar
camccardell
Alright, I haven't started my truck since, well I'd say september mabye?
I pulled the entire wiring harness and the upper intake manifold. I threw a rag over the lower intake and closed the hood.
Well after making a harness to go between the stock harness and the new 104 harness and ecm, I went out and hooked it all up.
At firs the engine wouldn't turn over. It was stuck at 1 position. I mean I could rotate the crank in reverse, but not complete and entire revolution. And if I rotated it back, it stopped in the same position. I suspected something somehow fell down and intake runner and I my suspision was confirmed, when it warmed up later today and with all the spark plugs out, it finally turned over and threw out some water droplets and ice particles.
Well after letting it turn over for a min or so to get the oil primed, I installed a new set of plugs and wires, and fired it up.
Huzzah it worked!
Well not all is great as there is something that sounds mechanically wrong with it. There is a noise that sounds similar to a lifter, yet this truck has roller lifters, so I doubt that is what it is.
Mabye I broke a piston ring?
other than that, I cannot guess what else it could be.
The noise changes with increased engine rpm, I mean it clicks at the same rate as the crank turns.
Any ideas guys?
Old Mar 24, 2008 | 08:24 PM
netscaner's Avatar
netscaner
Bent Valve or possibly a lifter problem after dead stopping the piston with water or ice.
Old Mar 24, 2008 | 08:26 PM
4x2mudder's Avatar
4x2mudder
if it clicks as the engine speeds up that could be piston slap, the piston could be slapping the head or their could be something foreign in the combustion chamber
Old Mar 24, 2008 | 08:40 PM
handsomerob's Avatar
handsomerob
Maybe you cracked something with that water freezing in there?
Old Mar 24, 2008 | 10:15 PM
78F150XLT's Avatar
78F150XLT
maybe an exhaust leak? check ur manifolds or headers, what ever you have on it... the bolts could be lose or the gasket could be burnt out or cracked.... just a suggestion.
Old Mar 25, 2008 | 07:01 AM
albung's Avatar
albung
how long u let it run? Roller or not the lifters are hydralic(sp) and need to pump up especally after sitting for a period of time
Old Mar 25, 2008 | 12:55 PM
Lazy K's Avatar
Lazy K
I`m with 4x2mudder, something embedded in a piston crown.
Old Mar 25, 2008 | 02:49 PM
camccardell
if there was somethign inthe chamber wouldn't the sound vary? I mean the sound is very consistent, not rattling around or changing at all.
What could it be? Any speculation?
And yeah, I might just need to let it run longer.... How long does it take to pump up lifters?
Anywho, I'm gonna pull the valve covers and see if any of the rockers have excess slack.
Old Mar 25, 2008 | 05:02 PM
camccardell
Horray, the sound mysteroulsy vanished!! I hope it stays away for good. New problems though. The OD light on the shifter is flashing and sometimes the check engine light comes on when I start it and other times it doesn't come on at all.
I need to install the obd2 harness and hook up a scan tool to it, and see what the heck is going on.
I'll let you know.
Old Mar 25, 2008 | 07:34 PM
camccardell
fixed the OD light, but the codes are for a o2 sensor and a crankshaft position sensor
where the heck is that?
Old Mar 25, 2008 | 09:29 PM
78F150XLT's Avatar
78F150XLT
My AODE OD light was flashing too when i drive down the highway when it goes into OD for a long period of time, it has stopped sicne i got the motor rebuilt, i just think lack of power which made the truck bog out and casue the tranny to heat maybe...
crank position sensor i belive is also known as the knock sensor, its located on the back of the water pump on the timing chain cover hidden behind your AC pump/ powersteering pump.
the o2 is in ur exhast, the cut out cat might be messn with it or if you change your crank pos. sensor it might go away cause your computer is trying to compinsate for the messed up sensor which is throwing everything outta wack!
when the TPS was shot in my truck, my nock sensor, purge canister, Throttle pos. sensor, and transmission sensor came up. I changed the TPS and it all went away...
holeshot434
Apr 5, 2014 08:04 AM
RIKIL
17
Jan 6, 2014 08:42 PM
normalmike
Nov 6, 2013 11:48 PM
Mud&Snow
1997 - 2003 F150
Sep 9, 2012 05:21 PM
bmonnig
Jan 11, 2007 08:48 PM
