'97 F150 Rear Drum to Disc Conversion
Originally Posted by lbftbljck
i have a 4x4 with an open rear. I think it has a 4.10 rear... that sounded a little high to me, but i called the local ford dealership and thats what the guy told me..
Like Bobby said, since you do have a 4x4, you will have to replace the rear axle with the same ratio axle as the one you have now. If you repalce it with a different axle ratio and it doesn't match your front axle ratio then this will throw the drive train into a bind whenever in 4WD high or low. It won't matter when in 2WD.
Check your door tag for the code listed under axle. It will tell you what is came with from the factory. Do you know the full history of the truck? Have the axle gears been changed from what was in it new?
Needed a work truck, couldn't afford covid pricing, so i bought an old 97. Never touched a drum brake in my life.. figured the time i spent learning old tech wasnt worth it. Decided to do a conversion. All the online conversion kits suck cause they make you buy their ****ty rotors and pads for 3x cost. No thanks. Found this thread, went out to the wreckers.. after looking in many door panels, turns out the 02 ford f-150 has an Axel 19, same as my 97. (More importantly, it uses disk brakes, and you'd need to take your rear axel shaft off regardless if you're using a conversion kit)..
Check the sticker inside your driver side door, then go hunting!! 10th digit is your year. Letters are 1980'-00' .. https://www.blueovaltrucks.com/tech-...v-i-n-decoder/ .. use that as a quick guide.
Still need to confirm the gear ratios are the same.. but im sure they are. Havent completed the swap yet, but figured I'd post this before i forgot.
Hope this helps someone.
Posting this in case anyone else finds this 14yrs later, like i did. I have faith there will still be many Triton engine's booting around.
Also, drums are simple once you go through one. Nothing wrong with a conversion but not wanting to learn drums is like buying new underwear everyday because you don't want to learn how to use those scary buttons on the washing machine.
tazaxx
32
08-04-2020 09:15 PM
fatheroftwo
04-21-2016 08:46 AM
