making biodiesel
making biodiesel
I found online how to make a sampe batch of Biodiesel, it said all i need is methanol, lye, and oil. Ok here come the questions
What type of oil do I use?
Where can I get lye?
I know that that HEET stuff for gas lines has methanol, is that what I use?
Also do I need to do anything to my truck if I do run Biodiesel in it? They have some at a local BP and its almost the same price as diesel...I just want to try it and see. So is it just a fill up and go thing?
Can it be mixed with diesel? or does my system need to be cleaned out?
Check out also www.biodieselcommunity.org----Use unused veg oil to test frist and you can get lye from Lowes plumbing dept. where the drain cleaners are (ROBEC CRYSTAL DRAIN CLEANER) good enough to test with. Good Luck!
are you talking about this one:
Make your own biodiesel: Journey to Forever
i am doing this this weekend. i see $5 diesel in the future and do not like it.
MAKO314
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-09-2008 06:14 PM
jerrytown2001
03-26-2008 10:14 AM
wbhinton
08-12-2006 07:05 PM
kennedyford
26
11-25-2005 09:05 AM
