1993 Ford Ranger Transmission Shifter Loose
How come the stick on my 1993 ranger transmission feels like it is in neutral no matter what gear I am in? The shifter goes in and out of gear without any problems, however; when in gear I am able to move it left and right just like as if it was in neutral.
Stu
Stu
Trans problem
Hey their Stu
If you to pull the shifter out. Sometime the end of the stifter could be worn. You might want to look and find a spare transmisson to have on hand.It's a sign that things are getting loose, I betting you got 150 + miles on it. I have a 91 ranger with 4.0L 4x4 And I,m on my third transmission. I don't use the 4x4 much but have a large fishing boat. Getting back to your transmission When your driving put your hand on your shifter if it feels rough or if you've notice it is getting noiser ,it a sign that the bearings are getting pitted. If your mechanicly handy and have good tools you can swap out the tranny in 4 hours If all goes well.
The only thing that can play havic is the manifold bolts, Use a torch and heat before tring to losen.
AJ46
AJ46
Highcountry30
11-06-2016 11:36 PM
Highcountry30
04-21-2016 03:10 AM
gladiator81
08-12-2015 11:06 PM
bliltzerman
1983 - 2012 Ranger & B-Series
11-28-2003 05:21 PM
