Towing with F150
Dpellicone..i think you will really like the F150. Is it the off road? If not...just add heavier rear shocks. My 2004 FX4 SC has never swayed with a heavy trailer on it! You can add Magnaflow stainless rear exit duals for around $500. Lifetime guarantee. Add K+N cold air in take...or add the Roush Charger!!!!!! I can't WAIT till my RoushCharger is done so i can go tow . I still have that 1942 Dodge 1 1/2 ton dump truck on my trailer. A little comparison is coming up!!!!!! Stay tuned. Joe
Originally Posted by jzlvr1
I just recently upgraded to a 2008 F150 from a 98 Mazda B4000 just to tow my TT. My TT is only 3000# emtpy. I bought it last fall so my B4000 could pull it. It could, but it struggled.
The new truck is excellent, I am really happy with it. However, I would like to get a tuner for it so I can tweak the settings. Since a turner had been mentioned a few times in this thread, I thought this would be a good spot to ask this question. What tuner is the best? And any recommendations on where to get it?
Thanks.
Daryl
Thanks.
Daryl
https://www.ford-trucks.com/forums/forum46/
Some-o-you guys seem to expect this guy to trade up to an F450 just so he can tow better once or twice a year. Depellicone, your truck will do fine if you stay within it's rated capacity and drive with some brainpower engaged. Yeah, you will suck fuel, but a little fuel is cheaper than a new truck (well, at least it is today!). Feel good that, right now, gas is much cheaper than diesel (here in Ohio, diesel is $4.05 per gallon while gas is only $3.24) and that almost cancels out the diesel fuel economy advantage unless you haul stuff for a living. Truckers, BTW, you have my heartfelt sympathy at the moment. Go west! Go west, young man, and TOW!
towing
The biggest problem you will have is trailer sway. even with trailer sway control the F150 sways a bit. As for pulling the weight it no problem . The people that say it has problems towing up steep grades so do most trucks. they all lose speed and slow down. I have 2 friends that I camp with one has a chebby 3/4 ton with a 454 and the other has a chebby diesel 3/4 ton They slow down almost as much as I do. If you don't over work your truck it will pull fine.
Just got back from towing my 28ft Shasta bunkhouse from Ann Arbor, Mi to Bristol,Tn for the races. 2004 FX4 Scab. Superchips tuner. Towed it down last summer with the Tow/Perf program installed, requires premium. This time I just used the 87 octane tune. Didn't notice a whole lot of difference. Truck does perform better with the tuner over stock. Biggest problem I had was with a trailer with about 800lbs tongue wt, the rear suspension had a tendancy to wallow in curves. New Ranchos when shocks were due. Best mod of all for towing was a pair of Firestone Ride-Rite air springs. About $250, no drill install on the new style 150. 60lbs inflation on both sides, adjusted the hitch height accordingly. Truck was rock, thats ROCK steady. Incredible difference. And believe me, I'm the biggest cinic in the world. Most of us tow large weights 1% of the time, and have to live with the tow vehicle the rest of the time. I can't afford to buy a 350diesel and park it. Had to anticipate the grades and give it throttle early and accordingly. With a little practice, got into a pretty good rythem and avoided sudden downshifts. Don't be afraid to stomp on it if you are slowing rapidly. Like a diesel, if you lose your rpm on a grade, tough to get them back. Truck and trailer was loaded with everything for the long weekend, so it was fairly heavy. We take everything including all adult beverages, so no once we're set up, nobody gets behind a wheel til its time to go home. (Just a race weekend tip) Truck would run at 70 in od on the flat, which was a surprise to me, but don't get used to it. Couldn't tow with cruise control, seemed to drop speed to far, requiring a downshift to get back to speed. Hope this helps.
Art Holland
Wayne, Mi
Art Holland
Wayne, Mi
Buy a good weight distribution hitch, a sway bar and an electric brake controller. Be patient when going up steep grades. There are more than a few programmers out there , but I use the Diablo Sport. I run the premium tune, but before I tow, I change it to the 87 octane tune so I don't detinate the motor.The truck you are concidering will tow fine.
I recently traded away my 2005 F250 Crew Cab FX4 6.0 for a 2008 F150 Crew Cab 6.5 ft bed. I havn't towed far, but I towed my loader on an open trailer without any problem, but it did strain a little on the hills. With the cost of diesel, I felt that I was better off with a gas truck. I tow once in a while, but most use is without a trailer.
I will be towing a 22 foot enclosed trailer for 800 miles later this year. I hope that it is without problems.
Dpellicone,
I have an '06 SCrew Lariat. Same drive train as your vehicle. We towed a Jayco 29 BHS (5600 dry. 7500 wet) from Winnipeg to Prince George British Columbia and back. It was a great trip. The truck performed great. The only sway I experienced was the bow wave from passing semi's. Gas mileage, yeah it suffered, but what the hey, either that and stay at home and grumble about being bored. It's all relevant.
Get a thicker side wall tire for sure, the Goodrich's I have are ok, with the tongue weight, the equalizer can only do so much in leveling.
Mountain driving was fine, but I would not tow with my vehicle with said camper along the Lake Superior route (Hwy 17?), Just too much up and down, where in BC it was one up, flat travel, one down in most cases.
Too be honest you may find that you are pushing the limit tho, smaller camper or bigger truck.
Cheers
Cheers
I downsized from a 05 f350 6.0 litre to an 07 F150 5.4l 3.73 last year. I pull a fifth wheel that has a dry weight of 6600 lbs. It pulls fine I don't use O.D. in the hills, I have not towed in moutains with new rig yet.
The F350 got 12 mpg average and the F150 10 mpg average towing. Since most of my driving is empty I for one am glad I got out of the diesel truck, by the way I have drove diesel pickups since 1986 6.9l.
#29
Ok but what about a 9000# fifth wheel? how do you think the 04 f150 5.4 3.73 would handle?
I have a chance at getting one for dirt cheap. We only travel a few times a year and the longest distance has been 300 miles one way. We live in the mountains so steep grades are the norm. I don't intend on racing to the top.
#30
