head crossover delete?
Old Mar 18, 2008 | 09:50 PM
jon87transam's Avatar
jon87transam
i've got a typical rusted out AIR crossover (back side of heads) on a 94 351. i've already deleted the smog, is there a plug i can use instead of a new tube that i can't actually use? if so, what vehicle do i need to look it up for? i'm sure there is a sbf that didn't use that pipe, i just don't remember what it was. thanks for the help.
Old Mar 18, 2008 | 10:42 PM
flareside_thunder's Avatar
flareside_thunder
I used SS bolts in mine...I wanna say 9/16 bout an inch long...or you can use old spark plugs......Luck
JR
Old Mar 18, 2008 | 11:34 PM
Blurry94's Avatar
Blurry94
You can use bolt and they'll work fine. Ford does sell thermactor plugs too if you're looking to go that route.
Old Mar 19, 2008 | 06:19 AM
jon87transam
oh, i didn't realize they were threaded! it was still hot when i pulled the tube off, so i didn't mess around back there! i'll def give that a shot, much easier. thanks a bunch!!! jon
Old Mar 19, 2008 | 10:30 AM
vasten's Avatar
vasten
What is the purpose of the cross over and is there a need for it?
Old Mar 19, 2008 | 10:36 AM
dvldog458's Avatar
dvldog458
Bolts with high temp RTV and large washers worked for me.
Old Mar 19, 2008 | 12:01 PM
Conanski's Avatar
Conanski
It's part of the air injection(Thermactor) system, it pumps air into the back of the heads or directly into the cats to help burn off excess hydrocarbons on cold starts.
