Would you trust it
Old Mar 18, 2008 | 12:51 AM
mudslingur's Avatar
mudslingur
Would you trust it
I'm going to start off by saying I know I'm not in the right forum,but i'm just trying to get as many opinions as posible ,so here it goes.
Yesterday I managed to put cracks on two of the bolt holes on the transmission bellhousing.Do you think the remaining four bolts can hold my c-6 transmission to my 351m engine.
Thanks
I know I'm an idiot
Old Mar 18, 2008 | 12:58 AM
Mil1ion's Avatar
Mil1ion
I would think so.
They really aren't stress points as it is the TC or clutch that does the spinning.
Which ones though did you crack ?
Old Mar 18, 2008 | 06:00 AM
fastfarmer's Avatar
fastfarmer
Four bolts should be enough, the important thing is that the mating surfaces of the tranny and engine are seated squarely together.
Old Mar 18, 2008 | 10:39 AM
mudslingur's Avatar
mudslingur
Thanks for the replys.I cracked the middle ones on both sides.So its being held together by the two top and two bottom.
Thanks again
Old Mar 18, 2008 | 06:01 PM
73f100shortbed's Avatar
73f100shortbed
You should be fine. You could probably use a large washer over the cracked holes to hold those bolts if you are worried but 4 should be fine.
