drivers door lock
drivers door lock
history 1990 F250 Driver door lock actuator stopped working. replaced actuator ,does not lock unlock. disconnect the rod to key lock everything works. every time I tried the key lock, te only way to get key out was in the position. With key in the inside locks worked. Key out do not work. I ordered a new lock set same problem. I did notice the rod from key to latch was loose and would move up and down with out doing anything. Not being able to find the right clip I zip tied it.
The Ford manual offered no help.
Aus56
06-28-2014 06:35 AM
