Starting Problems
Old Dec 16, 2000 | 10:02 AM
scalhoun's Avatar
scalhoun
Starting Problems
I've got a '77 F-150 351M that has starting problems. Sometimes she starts right up and other times just turns over and over and over. After playing around, I discovered that she will fire up when you release the key. In other words, I turn the key and the engine turns over but won't start. As soon as I let the key go back to the left it fires over. Someone told me this was a "ford problem." I'm gonna get a starter soleniod and ign switch. Any experience with this?
Thanks!
Old Dec 16, 2000 | 04:56 PM
Art's Avatar
Art
Starting Problems
Scalhoun,
I'd check to confirm that the POS side of the coil gets voltage in both the CRANK and RUN key positions.
Art
Old Dec 16, 2000 | 07:28 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Starting Problems
Sounds like a faulty ignition switch to me. I had the same trouble with an old Porche 924, and it turned out to be the switch. Good luck.
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Dec 20, 2000 | 04:16 AM
tall1's Avatar
tall1
Starting Problems
Does your solonoid have two small posts, if it does make sure the post with the I has a good connection to the wire. Also make sure the wire is in good shape. If the solonoid only has one small post then you're looking at a new switch in the dash. Check for voltage like these guys have said here also. I have had to wire up a push button start switch more than once and not only in fords - one was a saab
'79 F150 Stepside 4x4
351C-2V, 4 speed, 32/11.50 BFG MT's
'73 Mustang Grande
351C-2V, c-6
Old Feb 10, 2001 | 02:48 PM
glenn 79's Avatar
glenn 79
Starting Problems
It sounds like your ignition switch is getting stuck. It might
be time for a new switch.
Glenn
Old Feb 10, 2001 | 09:37 PM
Trail_Rider's Avatar
Trail_Rider
Starting Problems
It sounds like a power to the coil problem to me. I had this problem when I dropped my 351M into my '72. It turned out that I hadn't made an allance to fire the coil in the start position. I was able to overcome it with a relay but it wasn't until after I was done and had it running that I realized I could have done the same thing with a different solenoid.
Trail Rider
Old Feb 10, 2001 | 09:40 PM
Trail_Rider
Starting Problems
DG93
Aug 25, 2015 04:48 PM
markjones333
Jan 12, 2015 11:42 AM
95xltthumper
Oct 5, 2014 11:32 AM
ZombiePopper
Sep 24, 2014 05:37 PM
steeldust
Electrical Systems/Wiring
May 4, 2004 04:50 PM
