tie rod, brake problem ?
Old Mar 15, 2008 | 08:36 PM
red one's Avatar
red one
2000 4x4 Ranger, 80k miles. when I put on the brakes at slow speeds theres a slight clunk noise on the passenger side and then it pulls slightly to the right. Is this a brake problem and would the tie rods have anything to do with it. I've been told the drivers side upper tie rod is worn and should be replaced. Any help or suggestions would be appreciated
Old Mar 15, 2008 | 08:44 PM
michigan66's Avatar
michigan66
Is the tie rod end or the upper ball joint that is worn? A worn ball joint could give you the clunk. A worn tie rod end could produce the pulling. If either one is worn, it should be replaced. What happens with a firm brake application at high speeds?
Old Mar 16, 2008 | 06:11 AM
red one's Avatar
red one
at high speed brakes stop straight and quickly. i wonder if it is a abs problem it feels like front brakes release before they stop.
Old Mar 16, 2008 | 01:07 PM
red one's Avatar
red one
coud someone tell me what an anti-lock speed sensor os and what it does. thanks
2-5-OH!
Jul 1, 2013 05:56 PM
mtnxtreme800
Aug 14, 2012 07:00 PM
Kongslibakken
Jun 16, 2005 10:15 PM
fordrule13
1997 - 2003 F150
Mar 8, 2004 08:45 AM
