FX 4 Tire Size '08 F250
In order to keep the truck as low as possible for my 5th wheel, I want to order the LT275/65R 18E tire instead of the LT275/70R 18E tire - this is an option. This lowers the bed by about .5 to .75 inches (every little bit helps). Does anyone know if they recalibrate the speedometer or do they install diifferent gears in the speedometer when you order a tire different from the one that normally comes with the truck? Can this be done by a dealer if you change tire size later during the life of the truck?
Thanks for any info.
smcrea
01-26-2015 07:17 PM
WindLight
2009 - 2014 F150
03-12-2010 07:26 PM
