Just a thought. Convert a 460 to LNG
I know. This may sound ridiculous. I posted this in the alternative fuels forum. https://www.ford-trucks.com/forums/7...rsion-kit.html. Does this make sense or am I an idiot? Well, I'm probably an idiot, but...
What are your thoughts?
It is a good idea - and most conversions are duel fuel. I am not sure how they work the fuel injection issues, but assume it will work with FI.
It can pass Smog, if you follow their rules.
One big problem is that LPG needs much higher compression ratios to burn efficiently - on the order of 16 to 1. I have never seen a duel-fuel setup with this high a ratio. In tractors running only LPG the conversion works well - except for, as you noted, the need for extra large fuel tanks. The LPG engines I have seen were extremely clean and long lasting.
As for home refill kits - if you have your tank fitted with a bottom fill, you can draw liquid gas out of the tank without a pump. That is how I refill my smaller bottles. If you take it from the top all you get is gas. I guess you could re-compress it back to liquid with a pump - but I have no experience with that.
Also, in some states they put a stain in the home LPG gas which stains your carb so the cops can see if you have been running illegal fuel.
I'm kind of puzzled about this.
I suggest you contact the EPA and ask them. http://www.calepa.ca.gov/
I was not able to find the rules myself.
Natural gas has about 10% less energy than an equivalent amount of gasoline. I suspect that is why the higher compression ratio is desired. The range would certainly be reduced unless I were to add additional fuel tanks. But, if I could figure out a way to make it dual fuel, I could switch over to gasoline if I couldn't find anyplace to refuel.
I am really interested in this as well. I wonder if the old FE engines could be converted as well.
Will running LPG cause a loss of torque? I thought I heard that some SF busses couldn't be converted because they would not be able to pull the hills. I may be thinking of some other alt fuel/energy thing though.
It is common conversion in farm country where big engines run irrigation pumps, and around here for the wind machines. That may have changed some now that we have vehicle sized diesel engines that are price comparable.
They used it a lot in the oil patch - that way they could use their own gas direct from the well. My guess is that any rural gas supplier could give you information on conversions for stationary applications.
Natural gas is also used for rock crawlers engines. Since it is not a liquid, the off-road vehicle can handle more extreme angles without becoming fuel starved.
My guess it would be easier to convert your pickup because you don't have to pass California smog checks. Anything I would do would have to be CARB certified and I can't find any conversion kits.
I finally did a goggle search - there are legal conversion kits CARB approved for late model Ford applications.
For just a general understanding of what is needed: http://auto.howstuffworks.com/lpg5.htm
One company making conversion kits::http://www.hendrixsystems.com/index.htm
And one who has worked with the 5.4 L Ford and CARB: http://www.technocarb.com/
you will need to contact the company direct to see if they offer one for a 460 FI
If you aren't messing with air quality inspection stuff, check here for a start.
http://www.gotpropane.com/
Looks like fun, huh?
