92 e-250 pickup coil
Old Mar 12, 2008 | 08:25 PM
gyros's Avatar
gyros
My 351 has been diagnosed with a bad pickup coil,the distributor is siezed in the block and will not come out.The mechanic says it wil cost about$1000. to remove the dist. because he will have to break it off then remove oil pan to remove bottom of it, maybe jack up motor to do this.Then no guarantee because of possible metal pieces in engine.Any comments on this procedure,should I look for a new van? Thanks
