Code P0455
Old Mar 12, 2008 | 08:21 PM
kyle86's Avatar
kyle86
Code P0455
Im still srugling with problems with my Ranger. The most recent problem is code P0455 I have researched this problem extensivley and think I have found the culprit. On the purge canister behind the rear axle the metal tubes that come out of the canister wouble around a fair bit, I had originaly thought that it was the plastic quick connect fittings that were lose but its the metal tube its self that the fittings connect to that are wobbling. Is this normal or am I just smoking crack.
P.S Can this code cause idle problems and the EGR vavle to not function (Code P0401).
Old Mar 12, 2008 | 08:23 PM
kyle86's Avatar
kyle86
It is a 98 ranger 2wd 3.0 liter engine with a 5 speed manual tranny, 182,000k's.
Old Mar 14, 2008 | 06:49 AM
Rockledge's Avatar
Rockledge
The 401 code is more likely a bad DPFE sensor.
Since the 405 code points to a leak in the EVAP system, I'd say you might be onto something regarding those loose fittings.
Old Mar 15, 2008 | 06:41 PM
ticker's Avatar
ticker
PO0401 = EGR FLOW INSUFFICIENTI can't find a code P0455
Old Feb 5, 2009 | 09:01 PM
kyle86's Avatar
kyle86
I found the problem I replaced the water temp sensor it cost me $23 and with a little research i found that the emmision system will not turn on untill the water temp has reached a certan temp and my sensor had failed always reading -50F. I had brought it to a ford dealership I had paid them $200 to diagnos and they tried to sell me a new computer, bull****. The tech failed to over look every aspect that controls the emmisions sytem, even worsh he had been working there for 15 years and specialized in that area, dont trust any one.
ggenovez
1997 - 2003 F150
May 21, 2015 09:38 AM
mfp4073
May 7, 2015 10:25 PM
brentkhack
Crossovers
Apr 22, 2015 12:07 PM
Buck268
2009 - 2014 F150
Oct 4, 2013 09:51 PM
'01zr500
Sep 23, 2008 07:11 AM
